Starting my search
   / Starting my search #1
Bryan1965
Bronze Member
Hilliard, ohio
2016 Kubota L3901
We purchased 8 acres so we could use as a weekend getaway and spend our vacations in the summer and have a place for grandkids to get out of the city. The house sits on top of a hill, most of the property is far below this area. Most of yard is wooded, we have tried to clear a few areas. But it was untouched for years, a lot of growth. Had a neighbor bush hog a main path to the other side of property down the street. From that area, we have to go through a wet area to, get to back of property, in spring it was about 6 inches deep, once we get past that, it is pretty dry
I purchased a JD E140, but have blown 2 tires, and went through blades in like just a few times mowing spots we bush hogged, so will need something bigger
Was looking for a sub compact, but am worried it will be too small. My JD mower is 24HP hard to imagine a 24 HP tractor will be of great use on hills, especially since I want to take gravel down and try to make a land bridge past water area so the back of my property is not useless in spring
Also, will be taking wood up the hill to get to the house as plan on putting in a wood stove and outdoor fire pit.
Other than transport of gravel and wood, main purpose will be bush hog and maintaining or cutting paths into the wooded area.
Have been here for a few weeks, have learned more than I thought I would but still want advice as I make my search. Don稚 want to regret after I buy,
Of note, we own a home in Columbus Ohio, still make payments, there is a 125 year old house we are restoring, there was no septic, and may need to put in a cistern as water is not very good, a lot of iron, most people in area have cisterns also eventually want to put pole barn in, also restoration is not cheap, there were 20 some people living here and they were evicted about a year before we bought it, we do own the home, was able to get a good deal and paid cash.
But as you can imagine, Keeping cost down is essential,
Been looking at RK, but am worried, especially since 2 representatives mysteriously disappeared. Was thinking of RK 24, but am leaning toward RK 37, not sure I can afford a JD or Kubota that has the weight HP I think I need. Never heard of kioti or some of these other bands I have been reading about here. And not sure of dealers in area.
This is my starting point, open to suggestions and help sorry this is so long, wanted to give you as much info as possible so you know where I am at.
   / Starting my search #2
Congrats on the new place. You need to rethink somethings when you live in SE Ohio. There are not many places to purchase from nor get things repaired. There is a Kubota dealer in Quaker City that has been there for years. It may make your tractor selection easier. Also look for a low center of gravity. Get ag tires as the mud and snow will be a problem on the hills. Also load the tires and check for the addition of iron wheel weights. Purchase a good heavy rotary cutter. Watch CL for the area and you should be able to find other equipment used at a good price. Spend the money for a good solid gate and make sure you hire a neighbor to watch the place if you are not moving there. I grew up in Caldwell and I will never be able to live there again but I love the area.
   / Starting my search #3
Was looking for a sub compact, but am worried it will be too small. My JD mower is 24HP hard to imagine a 24 HP tractor will be of great use on hills, especially since I want to take gravel down and try to make a land bridge past water area so the back of my property is not useless in spring.
There is no comparison at all between a lawn cutter with a 24Hp gasoline engine and a SCUT with a 25Hp diesel engine. They are worlds apart in capabilities.
Don't be afraid to look at Blue. Those of who have like them as well as the extra cash in our pockets to buy other things.
   / Starting my search #4
I only have 6 acres but I went with a 48hp tractor in the 5,000lb range. I do a lot of lifting both front and rear. If you shop uses, especially 2wd, you can get a lot of bang for your buck in the 50ish range. I only paid $5000 with bush hog and loader used. Granted its 20-30 years old.
Do you have 2wd? I am worried about getting stuck especially on hills, I already had to use my ATV to get my JD unstuck
   / Starting my search #6
I have hills, and I wouldn't suggest 2wd, especially with a loader. In 2wd, I've gotten stuck on wet grass trying to go uphill.
thank you,
I worked on diesel and gas electric generators for about 20 years, I understand a 24 diesel will have more power, especially at lower rpm, which we need to lifting and other heavy work.
I still am worried about using a bush hog especially on hills. I have a prety steel hill to get up and down to the different elevations, especially if I am hauling logs or gravel. At least from many threads I have read here seems to be a big complaint. That’s why I was looking for 30 plus at the least unless people an talk me down.i almost got a 24 hp as it was well within my price range, but am worried
Thanks, that’s what I was worried about!
By blue I assume you mean new holland.
   / Starting my search #10
My suggestion is to get bigger than what you think you need because once you start using a tractor you will be amazed at the things you use it for.
378806 (A51572)
378806 (A51572)
New/Unused 30ft x 65ft x 15ft Storage Shelter (A51573)
New/Unused 30ft x...
2021 LIDDELL C-55 RGN (A52472)
2021 LIDDELL C-55...
2014 Chevrolet Tahoe SUV (A51694)
2014 Chevrolet...
2010 John Deere 1200A Bunker Rake (A50325)
2010 John Deere...
2005 MACK GRANITE (A52472)
2005 MACK GRANITE...
