Starting issues with Ford SU 4000 Diesel
/ Starting issues with Ford SU 4000 Diesel #1
jrmouse
Missouri
Ford diesel
Having problems with starting after it sits for awhile. It cranks but won't start. have changed fuel filter so that is not problem. Would appreciate any help to fix this. Didn't have to use it much this summer as it was so dry, so it hasn't been used for a couple of months.
/ Starting issues with Ford SU 4000 Diesel #2
Sounds like it may be losing it's prime. Check for broken line or fitting in fuel system, causing the fuel to drain back to tank, or onto the ground.
/ Starting issues with Ford SU 4000 Diesel #3
just changing the fuel fitler and waving your hand and saying 'that is not the problem' is empty words.
when cranking over is it making smoke?
what color?
have you bled the line to the pump and getting good flow there?
bled the injectors?
if plan pranny.. have you tried to pull start her? it's the easy way to bleed them..
post back
New/Unused ATS Electric Jack (A65583)
New/Unused ATS...
2022 Kubota Z422-54 Zero Turn Mower (A63689)
2022 Kubota...
2011 UD Thermoplastic Truck (A64194)
2011 UD...
KL480 Ventrac tiller
2006 John Deere 5425 (A64126)
2006 John Deere...
Case 2090 Tractor (A66285)
Case 2090 Tractor...
