Starting hay season 2017
   / Starting hay season 2017
Looks good. I fertilized a couple of days ago. Not sure if I messed up as it started raining shortly after application. Will probably top dress in a couple of weeks to add some additional nitrogen then I hope to be baling again at the end of the month.
   / Starting hay season 2017 #12
Nice, be sure to post some pictures of the hay process. Even though we have all seen it before.:laughing:
I bought this bale sweep so I wouldn't have to lift the hay in the trailer any more. It was sure nice. I could load the trailer in 10-15 minutes and not break a sweat.:D
   / Starting hay season 2017 #13
So all said and done I ended up with 400ish bales.
   / Starting hay season 2017 #14
Do you unload the trailer by hand? I have not seen a bale sweep unload before, Got 51 bales first cutting off of my 2 acres and have 12 acres cut and wind rowed ready for second turning then baling tomorrow. I cut a bit early to not have such thick stems. Blew a hose on my grapple (replaced locally within a hour or so), but otherwise even the sickle mower worked until I jammed the tip into a hole and sheared two knives off. Put on the replacement knife bar section and back at it. New rake is absolutely fabulous.
On edit. I noticed you have your hay on the concrete - ever any mold issue on the bottom? I have mine on pallets. I found the baler twine ones a perfect fit and tougher than most other full size ones.
   / Starting hay season 2017 #15
Different part of the world and different hay but I got 28 acres cut and bailed last week. only had a 4 day window but got it done.
   / Starting hay season 2017 #16
M5farms,
Hay and fields look great.
powerscol,
Yes I unload by hand. No choice the barn is to low for the tractor to fit. Otherwise I might have gone the grapple route. I don't mind to much, I can back in and unload right on spot. Plus it's a little exercise.
It sucks when you break equipment, glad you were able to get it fixed quickly. Just lucky this year but I didn't break anything. I did have a close call with a baseball sized rock in my neighbors field. It hit the post between my corner window and the back window. Couple inches either way and I'd be buying a new window.:eek:
As far as mold the answer is no. The only time I have dealt with mold is when I bale to wet. That only happened one time. (knocking on wood)
Well I hope to start second cutting in a week or so but may have to wait. Mother nature isn't cooperating to well as we're only got minimal rain and the fields are still short. Oh well gives me more time to move into the new house.
   / Starting hay season 2017 #18
I got really lucky this year. Hit a dry hot spell and finished cutting it about noon last Sunday and we baled it Monday afternoon. I have never had hay dry that quickly in this area. It is all grass though - tall fescue, brome and timothy. It was plenty mature but it has been too wet to cut it. Got an opening and took it.
   / Starting hay season 2017 #19
Like the saying goes; "make hay while the sun is shining". Glad it worked out for you.
   / Starting hay season 2017 #20
Some pictures of my little tractor gathering and stacking with the grapple. 221 bales in two trips.
0616171031.jpg0616171031a.jpg0616171031b.jpg0616171225.jpg0616171225a.jpg0616171347.jpg0616171347a.jpg
DROME EXCAVATOR SLIDE ATTEHMENT (A50322)
DROME EXCAVATOR...
2019 Ford F-550 Service Truck, VIN # 1FDUF5HY1KEF71327 (A51572)
2019 Ford F-550...
2012 LEEBOY 8515B APHALT PAVER (A51406)
2012 LEEBOY 8515B...
2018 INTERNATIONAL 4400 SBA 4X2 SERVICE TRUCK (A51406)
2018 INTERNATIONAL...
2016 Toro Groundsmaster 3505D 72in Rotary Mower (A51691)
2016 Toro...
Ryobi Sliding Compound Miter Saw (A51573)
Ryobi Sliding...
