Starting fluid use
/ Starting fluid use #1
casey lb1914
Upstate, New York
Kioti LB1914
Is there a problem with using starter fluid on my LB 1914 ? Friends say that it will destroy my engine if I continue to use it on cold starts. The only time it is used is on below 30 degree days. Thanks:confused:
/ Starting fluid use #2
Been using it on my 1971 backhoe for almost 20 years, with no ill effects. You only need to give it a slight sniff. The problem arises when people hose the starting ether into the intake, and then try and start the engine. The excessive ether causes the diesel engine to start much too hard, and there in where the problem lies.........It can cause engine lock up, and a good long wait is in order to allow the ether to evaporate off, and a new attempt to start is tried. I haven't had a problem, but I'm sure that there are horror stories.:rolleyes:
/ Starting fluid use #3
I have seen cracked cylinder sleeves and broken piston rings on tractors started with either. I have heard that once an engine gets started a few times on either, it will need it to start everytime. Not sure that one is scientific or a wives (husbands?) tale like swimming after eating gives you cramps....
/ Starting fluid use #4
A mechanic told me once that useing starting fluid in excess would damage the injector to the point you would have to use it all the time to get it to start.said it would burn the tips of the injector so they put a stream of fuel instead of a mist into the cylinder. Don't know if it is fact or not maybe bluechip can shed some thought on the possibility.
/ Starting fluid use #5
I would not suggest using either on a engine with glow plugs unless the glow plugs are unhooked other wise you will be looking at a very costly rebuild.
Rick
/ Starting fluid use #6
I remember using wd40 as a starting fluid for a diesel. It has been years ago.
Year: 2007 Make: Ford Model: F-250 Vehicle Type: Pickup Truck Mileage: 77,977 Plate: Body Type: 4 (A61573)
Year: 2007 Make...
2015 KOMATSU PC170LC-10 EXCAVATOR (A62129)
2015 KOMATSU...
2016 Deere 180G (A60462)
2016 Deere 180G...
2009 PROCO 130BBL (A65643)
2009 PROCO 130BBL...
New/Unused Wolverine Quick Attach 72in Grapple Bucket (A65583)
New/Unused...
72" JCT TILLER (A62613)
72" JCT TILLER...
