starting fluid ruins glowplugs?
   / starting fluid ruins glowplugs? #1
corelokt308win
I was getting a car inspected today and was talking with the mechanic about various mechanical problems I've had of late, and the Iseki glowplugs came up. He says starting fluid will ruin glowplugs, even after only one use. Is this so?
   / starting fluid ruins glowplugs? #2
</font><font color="blue" class="small">( I was getting a car inspected today and was talking with the mechanic about various mechanical problems I've had of late, and the Iseki glowplugs came up. He says starting fluid will ruin glowplugs, even after only one use. Is this so? )</font>
I was under the impression the problem was more along the lines of spraying starting fluid on hot glow plugs will ruin YOUR day...
   / starting fluid ruins glowplugs? #3
Don't know about your brand but Mitsubishi and Satoh diesel engines will not tolerate starting fluid. The piston tops are too thin. They use glow plugs. You should go to satohparts.com and look at the pictures of an engine damaged by ether. I know that some engines will take ether. We used it all the time on our farm tractors when I was growing up. However, constant use of ether will cause your engine to become addicted to it. This is because the additional volatility of the ether eventually rounds off the top of the piston rings. I don't know about whether ether will damage the glow plugs. If it won't start using the glow plugs you may want to make sure the glow plugs are working like the should. May also want to consider a block heater.
   / starting fluid ruins glowplugs? #4
Under no circumstance use either in a glow plug engine. That is the fastest way to destroying your engine.
2016 FORD F-250 PICKUP TRUCK (A52576)
2016 FORD F-250...
New/Unused 30ft x 65ft x 15ft Storage Shelter (A51573)
New/Unused 30ft x...
2009 Volvo VHD Tandem Dump Truck, VIN # 4V5KC9EF19N270338 (A51572)
2009 Volvo VHD...
2009 Ford F-150 4x4 Ext. Cab Pickup Truck (A51692)
2009 Ford F-150...
