Starting and fuel issues on Kubota M9000
   / Starting and fuel issues on Kubota M9000 #1
JeffreyOwens
Anderson, AL
Cub Cadet 3240, Kubota M9000
Having starting issues with Kubota M9000. Was bushhoging on hill side and tractor shut down. Added fuel bled fuel lines. Pulled off water separator. Cleaned it does need a new filter. Pulled fuel filter pored fuel out replaced pumped it back up. Tractor just turns over but will not start. Have pulled it to level ground. Any suggestions?
   / Starting and fuel issues on Kubota M9000 #2
is it making any smoke when turning over?
does it have any sort of fuel kill cable or solenoid fuel shutoff. make sur ethose are not stuck / pulled.
re bleed till you get fuel dribbling at the line before the injector.
if it is a straight gear model and you have a buddy, try a pull start. it's way easier on the starter and gets rpms up good.
post back
   / Starting and fuel issues on Kubota M9000 #3
Check for good fuel flow from tank to inj pump. Is fuel solenoid clicking?
2018 Rock Solid 8x28 Cargo Trailer - Generator & A/C, Work-Ready (A53472)
2018 Rock Solid...
2021 JOHN DEERE HX14 LOT NUMBER 14 (A53084)
2021 JOHN DEERE...
2009 Freightliner M2 106 MedTec Ambulance (A51692)
2009 Freightliner...
AT 26" x 11-12" (A52377)
AT 26" x 11-12"...
2001 HEIL PNEUMATIC CEMENT TRAILER (A52576)
2001 HEIL...
2021 JOHN DEERE HX14 (A53084)
2021 JOHN DEERE...
