Starting and fuel issues on Kubota M9000
   / Starting and fuel issues on Kubota M9000 #1
JeffreyOwens
Anderson, AL
Cub Cadet 3240, Kubota M9000
Having starting issues with Kubota M9000. Was bushhoging on hill side and tractor shut down. Added fuel bled fuel lines. Pulled off water separator. Cleaned it does need a new filter. Pulled fuel filter pored fuel out replaced pumped it back up. Tractor just turns over but will not start. Have pulled it to level ground. Any suggestions?
   / Starting and fuel issues on Kubota M9000 #2
is it making any smoke when turning over?
does it have any sort of fuel kill cable or solenoid fuel shutoff. make sur ethose are not stuck / pulled.
re bleed till you get fuel dribbling at the line before the injector.
if it is a straight gear model and you have a buddy, try a pull start. it's way easier on the starter and gets rpms up good.
post back
   / Starting and fuel issues on Kubota M9000 #3
Check for good fuel flow from tank to inj pump. Is fuel solenoid clicking?
NEW Slip On Fork Extensions (A53002)
NEW Slip On Fork...
2008 KOMATSU D39PX DOZER (A52577)
2008 KOMATSU D39PX...
CASE 580 SUPER N BACKHOE (A51246)
CASE 580 SUPER N...
2010 Chevrolet Tahoe SUV (A50324)
2010 Chevrolet...
2019 JOHN DEERE 8295R LOT NUMBER 183 (A53084)
2019 JOHN DEERE...
