Starting a propane generator
   / Starting a propane generator #1
nctacoma
Vermont
Kubota L4330
The other thread below got me thinking that the collective knowledge here could probably help me get this generator started.
We bought a house with a Briggs and Stratton generator hooked up to it. It has a propane conversion hooked up to it and I can't get it to start. I can't find any owners manuals for it so I am at a loss.
It is getting propane when I try to start it. The pull cord turns it over but it doesn't come close to firing. What should I check next? Spark?
   / Starting a propane generator #2
You must have 3 things for an engine to run and those are fuel, spark and compression. You need to figure out which is missing and why.
   / Starting a propane generator #3
Check to make sure it has enough oil in it. Gens will often have a sensor that will keep them from starting if the oil level is low. Easy to check and fix.
Keith
Scag Mower (A50324)
Scag Mower (A50324)
2021 CATERPILLAR D4 LGP CRAWLER DOZER (A51246)
2021 CATERPILLAR...
2007 Ford E-450 Super Duty 16ft Portable Office Truck (A54814)
2007 Ford E-450...
7060 (A53421)
7060 (A53421)
2016 Suzuki King Quad 500AXI 4x4 ATV (A51694)
2016 Suzuki King...
