Startin my Branson
/ Startin my Branson #1
melking
branson 3510I
When I try to start my Branson, I just get a click. If I try several times then eventually the starter will engage. Help?
/ Startin my Branson #2
I don't know he specifics of your tractor's starter system but it could be anythig from a weak battery, to corroded battery terminals, to a sticking neutral safety switch. Check those items out.
Thanks,
Someone told me that is was a bad solenoid but apparently in this model, the starter and solenoid come together
Appreciate the reply
/ Startin my Branson #4
You really need a volt meter to accuratly trouble shoot your problem.
Start with cheching battery voltage. Should be in the 12.6V range.
If good there, follow the positive cable to the where ever it hooks to next (probabally a solenoid) and confirm the voltage there. If all that is good, now check the voltage to the smaller wire at the solenoid with the key in the start position. You should see 12V there to energize the solenoid. If not, start working back from there.
If you dont have a volt meter, or dont know someone who has one, start with the basics. Clean terminals and make sure they are tight. Check all safteys and make sure they are making contact and plugged in. Neutral saftey, seat switch, pto switc, etc. If you still can figure it out, without a volt meter, you are probabally going to either need to buy one or take it to the dealer.
Rhino Servis 2160 Ditch Bank Mower (A62180)
Rhino Servis 2160...
2018 Freightliner M2 106 AWD Altec AA55 56ft. Insulated Material Handling Bucket Truck (A60460)
2018 Freightliner...
John Deere 5115M Tractor (A64047)
John Deere 5115M...
1998 CHEVEROLET 1500 LONG BED PICKUP TRUCK (A59905)
1998 CHEVEROLET...
500 BBL CENTEX WHEELED FRAC TANK (A63569)
500 BBL CENTEX...
Kubota M6800 Tractor w/ Loader (A64047)
Kubota M6800...
