Startin my Branson
/ Startin my Branson #1
melking
branson 3510I
When I try to start my Branson, I just get a click. If I try several times then eventually the starter will engage. Help?
/ Startin my Branson #2
I don't know he specifics of your tractor's starter system but it could be anythig from a weak battery, to corroded battery terminals, to a sticking neutral safety switch. Check those items out.
Thanks,
Someone told me that is was a bad solenoid but apparently in this model, the starter and solenoid come together
Appreciate the reply
/ Startin my Branson #4
You really need a volt meter to accuratly trouble shoot your problem.
Start with cheching battery voltage. Should be in the 12.6V range.
If good there, follow the positive cable to the where ever it hooks to next (probabally a solenoid) and confirm the voltage there. If all that is good, now check the voltage to the smaller wire at the solenoid with the key in the start position. You should see 12V there to energize the solenoid. If not, start working back from there.
If you dont have a volt meter, or dont know someone who has one, start with the basics. Clean terminals and make sure they are tight. Check all safteys and make sure they are making contact and plugged in. Neutral saftey, seat switch, pto switc, etc. If you still can figure it out, without a volt meter, you are probabally going to either need to buy one or take it to the dealer.
2016 Chrysler Town and Country Van (A61574)
2016 Chrysler Town...
KBH 1600 Gallon Water Trailer (A64047)
KBH 1600 Gallon...
2014 GENIE S-40 TELESCOPIC BOOM LIFT (A64279)
2014 GENIE S-40...
Arrow Quip 10' Bow Gate (A64047)
Arrow Quip 10' Bow...
Informational Lot - Financing (A63688)
Informational Lot...
JLG Scissor Lift (A64047)
JLG Scissor Lift...
