Thanks for all the quick replies. Let me run down and try to better describe the situation.
It is a riding lawn mower. I was cutting grass that was about 4 inches tall so no strain I would believe.
I tried with the plug out..the same. The plug was dry and the top of the piston was dry. I would assume if my rings were shot i would lose compression and have blow by. With the plug out i feel/hear air pushing out the hole. I threw in a new plug too.
Regarding jammed belts. nothing there. I can turn the motor by hand, turning the fan. Also no smell of rubber when it happen. I cut almost 200 feet before this happen.
Regarding the starter. The flywheel and drive are new. I replaced them last year. The drive fully engages. When I first started it up, it did with no problems. I pulled the starter away from the motor and tried it. It worked fine.
Regarding Battery. I'm sure I drained the battery with many attempts but i used a jumper pack then after hooked up to my truck. It would make one rev. i would have to help it by hand make another.
Regarding mice. I've had my battles with them and know their tactics. I saw no signs of them this time. The mower has it's own shed. After the last time they attacked, I surrounded the mower with traps, poisons to where the stupidest mouse knows to avoid it. I will check the muffler but even if there is internal damage such as valves, shouldn't the motor still give me more then one rev when trying to start?
Regarding Iplayfarmer question about speed of the rev., with a good battery on it, I would say normal. It's hard to really say though because it only makes one rev then stops.
Thank you for the suggestions. I'm sure when I bring what I bought home Tuesday, it's going to fire right up
I still would like to get this fixed. The thing has worked it's axle off over the years and hate to give up on it.
