Starter will not turn
/ Starter will not turn #1
landinflynn
Wheel horse T856
I've been working on a ls45 new holland ford rider thats been sitting for years and trying to bring it back pto switch works the seat switch works brake switch works plus three relays what could be happening with it? the starter works also and no oil sensor.
/ Starter will not turn #2
Can you jump pass solenoid or give the starter slight wrap.
/ Starter will not turn #3
Is the battery fully charged & passing a load test? All fuses ok? If the starter works (when bench tested, I assume), but not on the tractor, are you getting power to the solenoid when you turn the key? Good ground? Will she crank when you jump the solenoid on the tractor? Have you checked the cables & ground connections for resistance? I had to replace my ground cable, clean up the frame connections & replaced the crappy battery connectors with marine type terminals to get a decent connection on the posts. I've seen some posts of bad LS key switches. My LS was flooded by Hurricane Ian, she started once after I recharged the battery, but wouldn't start a second time, when I pulled the starter to test, saw the bendix and shaft were rusted solid & had to replace the starter. Depending on how long she's been sitting, I'd start with battery condition go to cable/connection cleanliness then starter internals (rust) in my approach to diagnosing. A good set of jumper cables run directly from the battery to the starter hot lug and an ear of the starter is a quick/easy way to see if the cables/connections on the tractor are your issue. Don't overlook fuses either ... low volts can drive amps up & blow fuses. When you get it figured out & putting together use lots of dielectric grease to minimize future problems.
John Deere QA Adapter (A64126)
John Deere QA...
2004 Chevrolet C4500 Western Hauler Truck, VIN # 1GBE4E1294F517585 (A65563)
2004 Chevrolet...
2014 FREIGHTLINER CASCADIA,TANDEM AXLE 6X4 SLEEPER TRACTOR (A59914)
2014 FREIGHTLINER...
2020 Bobcat E55 (A64126)
2020 Bobcat E55...
2018 Dodge Charger Sedan (A64557)
2018 Dodge Charger...
275 Gallon Cage Tanks, Koser Safe, with 2" outlet (A62679)
275 Gallon Cage...
