starter will not crank engine
   / starter will not crank engine #1
randyrest
troy il
800 ford
860 ford converted to 12v Yesterday I started it with no problem. Today I push the start button and nothing. I took a jumper cable and went from the + side of the battery (which has a full charge) to the wire lug on the starter and nothing. I took the starter out and put in a brand new starter. Before I put the new starter in I connected the jumper cable to it and it spun. I put it in and nothing. I even wire brushed the metal where the starter bolts to the tractor. I put the jumper cables on the starter I just took out and it spun. What the heck happened from one day to another. I wire brushed all battery connections and the ground cable. Anybody have an idea?
   / starter will not crank engine #2
I had a very similar problem with my super a. New starter wouldn't crank once everything was installed.
I bought a digital voltmeter that had a setting to check the circuit continuity. Turns out my battery box was blocking the battery terminal from grounding. (even after wore brushing everything)
Without the meter, I never would have found where the circuit was failing.
Good luck!
   / starter will not crank engine #3
Try connecting your jumper cable from the battery negative terminal straight to ground on the engine(sort of bypassing the existing ground cable) and see what that does. I suspect you just have a poor connection to ground.
   / starter will not crank engine #4
I've commonly added extra grounds on some equipment I was unsatisfied with the condition of original grounding. Can't have too much ground. :)
PAIR OF 607 CHALLENGER PUMPS (A53843)
PAIR OF 607...
New Holland TS 75 Front Loader Utility Tractor (A53421)
New Holland TS 75...
2012 JOHN DERE 310K BACKHOE (A51406)
2012 JOHN DERE...
PALLETS OF HEAVYEQUIPMENT (A53843)
PALLETS OF...
2020 MDB UT125KPLUS FLAIL MOWER (A51247)
2020 MDB...
2005 Isuzu NPR Venco VC516 Landscape Dump Truck (A53422)
2005 Isuzu NPR...
