Starter Trouble Shooting
   / Starter Trouble Shooting #1
marks
San Luis Obispo, CA
JD 870
My DR Mower has a 14hp Kawasaki, which normally starts fine. After sitting for the past several months and having recharged the battery, the starter is grounding out, as in arcing at the negative terminal. The battery cables are connected properly, yet somewhere it's going to ground. The brushes and armature look okay, yet is there some way I can test the solenoid? Thx
   / Starter Trouble Shooting #2
Have you removed the cable and cleaned it and the terminal?
   / Starter Trouble Shooting #3
Remove starter; should be pretty obvious where short is.
   / Starter Trouble Shooting #4
Mark, this is Steve from DR. I supervise Customer Service. The issue you're describing could be caused by one of a few things. The best course would be to call our free Technical Support line at 800-376-9637 and have one of the tech reps troubleshoot your problem. They can also be reached via email at info@drpower.com
I'm confident that they can point you in the right direction to solve your issue. Thanks,
Steve Miksek
   / Starter Trouble Shooting #5
Steve Miksek
This is impressive. No I have no DR equipment nor any relationship with them in any manner.
2014 International DuraStar 4300 4x4 Terex BT3063 63FT 15 Ton Crane Truck (A51692)
2014 International...
12in Mini Excavator Tooth Bucket (A52377)
12in Mini...
2012 Cadillac SRX SUV (A53424)
2012 Cadillac SRX...
2018 UTILITY VS2RA 53FT REEFER TRAILER (A54607)
2018 UTILITY VS2RA...
Kenworth Tri Axle Dump (A47384)
Kenworth Tri Axle...
2018 FORD F-450 XL FLATBED TRUCK (A51406)
2018 FORD F-450 XL...
