Starter Trouble Shooting
   / Starter Trouble Shooting #1
marks
San Luis Obispo, CA
JD 870
My DR Mower has a 14hp Kawasaki, which normally starts fine. After sitting for the past several months and having recharged the battery, the starter is grounding out, as in arcing at the negative terminal. The battery cables are connected properly, yet somewhere it's going to ground. The brushes and armature look okay, yet is there some way I can test the solenoid? Thx
   / Starter Trouble Shooting #2
Have you removed the cable and cleaned it and the terminal?
   / Starter Trouble Shooting #3
Remove starter; should be pretty obvious where short is.
   / Starter Trouble Shooting #4
Mark, this is Steve from DR. I supervise Customer Service. The issue you're describing could be caused by one of a few things. The best course would be to call our free Technical Support line at 800-376-9637 and have one of the tech reps troubleshoot your problem. They can also be reached via email at info@drpower.com
I'm confident that they can point you in the right direction to solve your issue. Thanks,
Steve Miksek
   / Starter Trouble Shooting #5
Steve Miksek
This is impressive. No I have no DR equipment nor any relationship with them in any manner.
2019 MACK PINNACLE P164T DAY CAB ROAD TRACTOR (A51406)
2019 MACK PINNACLE...
AUCTION STARTS HERE @ 9AM (A51406)
AUCTION STARTS...
2018 Ford Fusion Hybird (A53424)
2018 Ford Fusion...
2015 JOHN DEERE 624K WHEEL LOADER (A51406)
2015 JOHN DEERE...
2002 Ferguson SP915RE Ride-On Pneumatic Asphalt Compactor (A52377)
2002 Ferguson...
2015 Freightliner Bucket Truck (A52748)
2015 Freightliner...
