Starter Solenoid throwing sparks
   / Starter Solenoid throwing sparks #1
LaytonAg
When I tried to start my YM2310 on Saturday I noticed sparks from the engine compartment. So, I opened the hood and observed while I had my son try to start the tractor. I saw sparks coming from 1 of the two large lugs on the end of the starter solenoid. I tried to start it again and just get a loud clicking sound when I turn the key all the way over. What do the sparks mean? Has anyone experienced this? Thanks.
   / Starter Solenoid throwing sparks #2
Did you check the connections at the solenoid to see if they were tight? sounds like a loose connection. The clicking sound is the solenoid trying to engage but not getting enough current.
   / Starter Solenoid throwing sparks #3
I would go ahead and remove and clean the connections just to make sure you have a good clean ones. Just because you tighten them up does not mean you have a good connection. I woud also check and clean if needed my battery and the ground to the tractor while I was at it.
Carey
   / Starter Solenoid throwing sparks #4
Sounds like battery is about shot.
   / Starter Solenoid throwing sparks #5
Carey
Sound advice. Troubleshooting any electrical problem needs a good starting point and that is how you get there.
   / Starter Solenoid throwing sparks #6
it is either loose connections on the starter terminals or the contacts in the cap are arcing out due to a bad contact
Thanks to all for the strategies for solving. I took the connectors off of the solenoid and cleaned them up with a little steel wool and tightened them up good and the tractor started right up.
2018 HINO CONVENTIONAL TYPE TRUCK (A52472)
2018 HINO...
CUSHMAN HAULER PRO GAS GOLF CART (A54756)
CUSHMAN HAULER PRO...
UNUSED X-STAR 101" X 20' LOADING RAMP (A51247)
UNUSED X-STAR 101"...
2019 HarbinGer V3 Plus 8KW S/A Towable Light Tower (A52377)
2019 HarbinGer V3...
JOHN DEERE XUV835M (A53084)
JOHN DEERE XUV835M...
