STARTER-SOLENOID-SWITCH PROBLEM ?
/ STARTER-SOLENOID-SWITCH PROBLEM ? #11
I would recommend opening up the solenoid and check it out. It is not a difficult task.
If you want to PM me your Email address, I will send you a PDF file with pictures, etc of solenoid disasembly.
Thanks Bob, erj & all replies,
I removed solenoid from starter and disassembled & found not too much wear on the copper but a hard black film all over the contacts
Resurfaced the copper studs & turned the circle disc over on the shaft & put back together
Removing & putting back the little lock rings on the shaft, & de-soldering the contacts to remove then routing the wire back thru to re-solder was the most frustrating, but it was not too bad
Starts fine now
David
KJ K0720 7'x20' Metal Gate (Deep) (A60463)
KJ K0720 7'x20'...
2016 FORD F-250 SUPER DUTY (A58214)
2016 FORD F-250...
ELECTRIC GOLF CART (A58214)
ELECTRIC GOLF CART...
KENT HYDRAULIC HAMMER ATTACHMENT (A60736)
KENT HYDRAULIC...
2020 CATERPILLAR 306 CR EXCAVATOR (A60429)
2020 CATERPILLAR...
STEPP SEALCOATING MACHINE (A59906)
STEPP SEALCOATING...
