Starter Relay part /cross reference
/ Starter Relay part /cross reference #1
cabin kioti
Sullivan County Pennsylvania
ck 30 hst
I have a 2006 CK30 HST and I think the starter relay is going bad. I would like to order a set because the tractor is 60 miles from me and no parts store in the area there. I have been looking on line with no success. Thanks for any help. I have the parts manual but it is at my cabin also.
/ Starter Relay part /cross reference #2
Are U sure about the relay?
Those switches have a lubricant to assure smooth operation.
The lube dries up and then contact gets very iffy.
Squirt some WD40 into the key slot and you might just be surprised.
My 2 cents!
(been there done that)
/ Starter Relay part /cross reference #3
Do lube the switch first. I think these from Amazon will work fine to replace the start or stop relays.
/ Starter Relay part /cross reference #4
There are a number of threads that have referenced this information before, do a search here and you should be able to find the information you are looking for.
Rancho
CK20 HST
275 Gallon Cage Tanks, Koser Safe, with 2" outlet (A62679)
275 Gallon Cage...
WACKER NEUSON LIGHT PLANT (A65643)
WACKER NEUSON...
2005 Great Dane Dry Van Trailer, VIN # 1GRAA56185K270688 (A61165)
2005 Great Dane...
New/Unused Landhonor Mini Skidsteer (A65583)
New/Unused...
International MaxxForce 6-Cylinder Turbo Diesel Engine with Transmission (A59228)
International...
PREVIEW DATES AND TIMES (A65563)
PREVIEW DATES AND...
