Starter Relay part /cross reference
   / Starter Relay part /cross reference #1
cabin kioti
Bronze Member
Sullivan County Pennsylvania
ck 30 hst
I have a 2006 CK30 HST and I think the starter relay is going bad. I would like to order a set because the tractor is 60 miles from me and no parts store in the area there. I have been looking on line with no success. Thanks for any help. I have the parts manual but it is at my cabin also.
   / Starter Relay part /cross reference #2
Are U sure about the relay?
Those switches have a lubricant to assure smooth operation.
The lube dries up and then contact gets very iffy.
Squirt some WD40 into the key slot and you might just be surprised.
My 2 cents!
(been there done that)
   / Starter Relay part /cross reference #3
Do lube the switch first. I think these from Amazon will work fine to replace the start or stop relays.
   / Starter Relay part /cross reference #4
There are a number of threads that have referenced this information before, do a search here and you should be able to find the information you are looking for.
Rancho
CK20 HST
Year: 2012 Make: Ford Model: Fusion Vehicle Type: Passenger Car Mileage: 61,276 Plate: Body Type: 4 (A50324)
Year: 2012 Make...
TEST BID LOT (A50775)
STORAGE FEES (A52141)
2015 DODGE RAM...
Swict 66" Bucket (A50121)
Swict 66" Bucket...
PENDING SELLER CONFIRMATIONS (A52141)
PENDING SELLER...
