Starter "R" terminal
   / Starter "R" terminal #1
Shimon
Platinum Member
Sedro Woolley, WA
Kubota L3400 (gear driven)
On gas engines some starters have the "R" terminal which usually had a wire going directly to the ignition coil to bypass the ballast resistor (on the older points ignition engines) during starting so the coil had full battery voltage.
Does anyone know exactly what the "R" stands for? I always thought it stood for "relay" but I've also heard it stood for "resistor bypass". Anyone know for sure. Did some searching on Google but couldn't find a definitive answer.
Thanks.
1994 INGERSOLL RAND SD100D PADFOOT ROLLER (A52706)
1994 INGERSOLL...
UNUSED (2) 7000# DROP AXLES W/ BRAKES (A54756)
UNUSED (2) 7000#...
2000 Freightliner FL70 Manitex 14 Ton Crane Truck (A55788)
2000 Freightliner...
2023 54' Hooklift Dumpster 20 Cubic Yard (A53422)
2023 54' Hooklift...
2014 FORD F250 XL SUPER DUTY CREW CAB TRUCK (A51406)
2014 FORD F250 XL...
2012 International 4300 Vacuum Excavation 7.6L Diesel Truck w/Vanair Vacuum (A51692)
2012 International...
