Starter on Ford 851
   / Starter on Ford 851 #1
851 roger
Bronze Member
Wheatland, Oklahoma
Ford 851 Powermaster
The starter is just spinning on this Ford 851 Powermaster. It is not turning the engine over. I dont know what to check. I can pull it if I need to, but is the something I should check before removing it. It is turning but not engaging to the flywheel. Not like a car starter so I'm kinda lost here. Help!!!!
   / Starter on Ford 851 #2
I believe the bendix has to kick the starter out to engage the flywheel. If this does not take place the starter will just spin because your gear does not engage the fly wheel and thus not turning the engine over. Sounds like you need to take your starter to the repair shop. Should be a relative cheap fix.
   / Starter on Ford 851 #3
I would put the tractor in gear and rock it, often they will get a bad spot on the starter ring gear and not turn over. My 8N has more bad spots than good. If that does not work then see about pulling the starter and make sure that the starter drive is in good shape.
   / Starter on Ford 851 #4
Try above first. If rocking in high gear doesn't work, then try tapping on the starter with a plastic hammer or something similar. Don't pound too hard, or you'll damage the starter. Of course, make sure the battery is fully charged.
If none of the above works, pull the oil filter then the starter. It isn't really a big deal. Inspect the bendix and ring gear for wear. The bendix may benift from a little wd-40.
   / Starter on Ford 851 #5
Sometimes a new Bendix gear will add a bunch more starts to the life of a worn ring gear. Did that with an older BMW 535 and it went two years without that sickening free-spinning.
Jim
2013 John Deere 824K Wheel Loader (A53473)
2013 John Deere...
Adams 6T Fertilizer Spreader (A53473)
Adams 6T...
2025 Mower King SSRC (A50123)
2025 Mower King...
2012 SOUTHERN VAC KILL TRAILER (A53843)
2012 SOUTHERN VAC...
2012 Mazada 3 Sedan (A51694)
2012 Mazada 3...
2016 KENWORTH T270 SERVICE TRUCK (A51406)
2016 KENWORTH T270...
