Starter on Ford 851
/ Starter on Ford 851 #1
851 roger
Wheatland, Oklahoma
Ford 851 Powermaster
The starter is just spinning on this Ford 851 Powermaster. It is not turning the engine over. I dont know what to check. I can pull it if I need to, but is the something I should check before removing it. It is turning but not engaging to the flywheel. Not like a car starter so I'm kinda lost here. Help!!!!
/ Starter on Ford 851 #2
I believe the bendix has to kick the starter out to engage the flywheel. If this does not take place the starter will just spin because your gear does not engage the fly wheel and thus not turning the engine over. Sounds like you need to take your starter to the repair shop. Should be a relative cheap fix.
/ Starter on Ford 851 #3
I would put the tractor in gear and rock it, often they will get a bad spot on the starter ring gear and not turn over. My 8N has more bad spots than good. If that does not work then see about pulling the starter and make sure that the starter drive is in good shape.
/ Starter on Ford 851 #4
Try above first. If rocking in high gear doesn't work, then try tapping on the starter with a plastic hammer or something similar. Don't pound too hard, or you'll damage the starter. Of course, make sure the battery is fully charged.
If none of the above works, pull the oil filter then the starter. It isn't really a big deal. Inspect the bendix and ring gear for wear. The bendix may benift from a little wd-40.
/ Starter on Ford 851 #5
Sometimes a new Bendix gear will add a bunch more starts to the life of a worn ring gear. Did that with an older BMW 535 and it went two years without that sickening free-spinning.
Jim
2022 CATERPILLAR 299D3 XE SKID STEER (A65053)
2022 CATERPILLAR...
2012 Mini Cooper Coupe (A61574)
2012 Mini Cooper...
2026 NORSTAR IRONBULL T/A 25FT GOOSENECK TRAILER (A59912)
2026 NORSTAR...
2019 International LT625 Sleeper 48 (A62613)
2019 International...
Caterpillar RM-350/RM-350B/SM-350 Reclaimer Mixer Service Manuals (A63117)
Caterpillar...
2013 INTERNATIONAL DURASTAR 4300 M7 SWEEPER TRUCK (A63276)
2013 INTERNATIONAL...
