Starter Motor XG3037
   / Starter Motor XG3037 #1
alexsbuddy
Diamond, MO
LS XG3037 w/ LS LL3109 FEL Kodiak SD5 Mower, Speeco Model 65 PHD, Bush Hog BX-600 Box Blade, Titan 42" Skid Steer Pallet Fork/Hay Spear Combo
Well, I thought I had the starting issue solved, but it turned out that the clutch pedal safety switch was not the issue. It wouldn't start again and turns out it is the solenoid on the starter...had it bench tested to make sure. Has anyone else had any luck replacing just the solenoid on an LS starter, #40305984, or finding a replacement starter for this model?
   / Starter Motor XG3037 #2
try a local starter/alternator rebuild shop
Did that today. Am hoping for good news, but thought I would get some more input from others, too.
   / Starter Motor XG3037 #4
:thumbsup:
just the solenoid would have to be a lot cheaper than replacing the whole starter
Caterpillar D5K2 LGP Crawler Tractor Dozer (A50322)
Caterpillar D5K2...
2020 KOMATSU PC360LC-11 EXCAVATOR (A51242)
2020 KOMATSU...
2021 JCB 1CXT Skidloader/Backhoe (RIDE AND DRIVE) (LIKE NEW) (A50774)
2021 JCB 1CXT...
HYDRAULIC PUMP FOR JOHN DEERE 544 WHEEL LOADER (A51244)
HYDRAULIC PUMP FOR...
2020 MDB UT125KPLUS FLAIL MOWER (A51243)
2020 MDB...
2017 NISSAN NV200 VAN (A51406)
2017 NISSAN NV200...
