Starter motor is knocking loud no engine turn over! Help!
   / Starter motor is knocking loud no engine turn over! Help! #1
Dirtmover22
Mahindra emax 22L HST
My emax 22l HST has a loud knocking or hammering noise from the starter motor. No engine turn over! Wont Start! Help Please!
   / Starter motor is knocking loud no engine turn over! Help! #2
I'd start by shifting into neutral - perhaps a space between ranges - to see if the starter will turn the engine over. If not try rotating the engine by hand, perhaps using the front crankshaft bolt with a socket and breaker bar. This will let you know if the engine is seized.
   / Starter motor is knocking loud no engine turn over! Help! #3
Starter gear may either not be meshing with engine or the solenoid that pops out the shaft is not going out far enough.
If you can turn the engine a little safely and then try, it would rule out engine seized and starter gear not meshing in one go.
Make sure you are in neutral during any of this testing.
   / Starter motor is knocking loud no engine turn over! Help! #4
You could also pull the starter and examine the teeth on the ring gear and the starter. The knocking could be worn down teeth slipping past each other
Thank you all for your replies! I will try the suggestions and I'll let you know.
UNUSED FUTURE BD43 HYD BACKHOE ATTACHMENT (A51248)
UNUSED FUTURE BD43...
2013 FREIGHTLINER EXT CAB SERVICE TRUCK (A51406)
2013 FREIGHTLINER...
BANDIT ZT1844 RUBBER TRACK STUMP GRINDER (A50458)
BANDIT ZT1844...
GALAXY - SET OF 19.5L-24 INDUSTRIAL R4 TIRES (50% TREAD) (A53472)
GALAXY - SET OF...
Redirective Crash Cushion Guardrail (A51692)
Redirective Crash...
UNUSED WOLVERINE CB-11-750F HYD CONCRETE BREAKER (A51248)
UNUSED WOLVERINE...
