starter leaking oil?
   / starter leaking oil? #1
cartime
South Ga.
L 175 19??
Someone please help. I have an L 175 and it is leaking hyd fluid out of the starter,any suggestions? /forums/images/graemlins/confused.gif /forums/images/graemlins/confused.gif
   / starter leaking oil? #2
That never happen to me with my Kubota, but something like that happened maybe 15 years ago when I was using a Farmall 200. While baling hay, I was confronted with a sudden loss of hydraulic fluid level but with no apparent leak. Since clouds were thickening and rain threatening, I had to continue with the haying, so I kept adding fluid until I was done. When I got back to the shop, hydraulic fluid was coming out from the strangest places, including the starter motor. I found that the shaft seal on the hydraulic pump failed, overfilling the crankcase with fluid. The volume overcame the crankshaft rear seal and filled the clutch housing with fluid until it came out the starter. What a mess!! I don't know if such a thing could happen with your Kubota, but it could be easily detected by checking the oil level in your crankcase. The replacement seal cost only a couple bucks, But the cleanup of the clutch was, lets say, somewhat labor intensive!
Frank Z.
   / starter leaking oil? #3
Your starter is in a dry area of the engine, could you be mistaking the hydraulic pump for the starter? The starter doesn't come in contact with an area that has oil. Also could it be leaking something from above the starter and it's dripping down? Just ideas to check.
Unused 2025 Spirit Electric Mini Golf Cart (A51694)
Unused 2025 Spirit...
2017 Peterbilt 220 16FT Box Truck (A51692)
2017 Peterbilt 220...
1994 Fiat Allis 65-B Motor Grader (A52384)
1994 Fiat Allis...
LOAD OUT INFORMATION LOT NUMBER 4 (A53084)
LOAD OUT...
2014 Doyle Dry Fertilizer Tender Trailer - Kubota Diesel, 3 Stainless Compartments, Side Discharge (A53473)
2014 Doyle Dry...
2016 Big Tex 24ft. T/A Flatbed Trailer (A50323)
2016 Big Tex 24ft...
