Richard
Super Member
- Joined
- Apr 6, 2000
- Messages
- 5,085
- Location
- Knoxville, TN
- Tractor
- International 1066 Full sized JCB Loader/Backhoe and a John Deere 430 to mow with
As per another thread, I replaced my solenoid on my starter yesterday.
I'm a little confused. If you will pardon any butchering of words, here's what I've got.
The solenoid has three terminals. Two heavy lugs and one "trigger" tab. Unless I went dumb in the meantime, when I took the old one off I had a heavy copper strap from one lug of the solenoid to the base of the starter itself. I presume this is the heavy current to actually crank the motor.
The other lug had the heavy wire from the battery and a cluster of maybe three other wires bundled together.
The last attachment point is the little 'trigger' tab that for lack of better word, is the lead to the key that starts the whole process.
Oh, and the very bottom of the starter has another couple of wires bundled to it as well. Perhaps just a grounding point for them, I don't know.
All I did was take the old solenoid out, put the new one back.
I went to crank it and let go of the key. The engine kept cranking & cranking & cranking as though Casper the Ghost was still holding the key.
Fortunately, I have a blade style quick disconnect to my negative post (to kill any chances of battery drain during weeks or months of non-use) and I was able to lift the blade to kill the starter.
Tried it again and same thing....just kept cranking away.
huh?
I'll admit I'm dumfounded on this. I got the machine started, and lifted the disconnect. With the noise of the engine starting, I don't really know if the starter disengaged on its own or if the breaking of the circuit by me did it. Everything works fine once started.
It was getting dark so I drove the machine out of my father in laws lawn and brought it home and parked it.
I'll probably get back to it this weekend.
What might cause the starter to STAY in starter mode?
Here's one thought I had. As I recall, when the solenoid is energized it pushes (or pulls?) a lever and this moves the bendix gear inside the starter. This process ALSO connects some contacts to deliver the heavy current to actually engage the starter itself.
The plunger on the solenoid fits into a slot on the starter side. If perchance, this didn't fit properly and therefore, created a "larger" length plunger, could this phantom extension be keeping these contacts touching each other until I lift the negative lead on the battery??
huh?
