Starter JD Gator 620i
   / Starter JD Gator 620i #1
Snr2snt
Milton,fl
John deere gator 620i
Could someone please give a little help on changing starter on gator 620i..I've read other forums and not accurate info..would rather hear it from someone who has gator 620i
   / Starter JD Gator 620i #2
:welcome: to TBN
What problem are you running into and what are you finding to be "not accurate" ??
If going to work on it yourself (DIY), then I'd suggest to get a copy of the service tech manual for the 620i. It will prove to be very helpful and save you $$$
Find at the dealer or on the net..
The problem was getting to top bolt of starter without taking solenoid off,and then is still a pain...However, by taking off outside of belt housing and drill 1/2 in hole in line with top bolt of starter through inner belt housing. The project can be done in about 1 hr. Once starter is installed used silicone gasket maker to plug drilled hole....thanks to those who replied..hope this helps others with 620i gators..
   / Starter JD Gator 620i #4
Seems like a reasonable solution to a problem. But still at an hour to remove and replace a starter does not sound like the JD people gave this much thought when designing the unit.
Richard
2019 CATERPILLAR 326FL EXCAVATOR (A51242)
2019 CATERPILLAR...
2015 Cadillac Escalade ESV Platinum AWD SUV (A50324)
2015 Cadillac...
Walking Floor Trailer 43ft (A50322)
Walking Floor...
2018 JLG 3246ES 32ft Electric Scissor Lift (A50322)
2018 JLG 3246ES...
2025 12V Diesel Pump and Hose with Meter (A50324)
2025 12V Diesel...
John Deere 4020 Tractor (A50514)
John Deere 4020...
