Starter for Allis Chalmers HD-3 or D-15 Diesel
   / Starter for Allis Chalmers HD-3 or D-15 Diesel #1
SheldonSwearengin
Cottage Grove, OR
Allis Chalmers HD-3
I'm looking for a new starter for my Allis Chalmers HD-3 (D-15 Diesel uses the same starter). I have found many part numbers but all are obsolete and don't cross over to a valid part number. Can anyone help?
   / Starter for Allis Chalmers HD-3 or D-15 Diesel #2
Wouldn't a regular Delco Remy starter from any Detroit 2/71 fit.
There's an old Allis HD-3 at the farm but its tic season, I'm allergic to the buggers. So your part number would have to wait until fall and I'm sure someone on this forum will have it for you long before the snow flies.
   / Starter for Allis Chalmers HD-3 or D-15 Diesel #3
I may know where a used starter for one is
Thanks but I have a Used one that I'm looking at having rebuilt but I want a good part number for a new starter. I'm repurposing the engine and putting it in my boat and need the ability to just buy or order a replacement without going through what I am now for parts.
   / Starter for Allis Chalmers HD-3 or D-15 Diesel #5
I am not sure that you will be able to find a new one. I know parts for those are getting really hard to find. Good luck though!
I don't know but I'll look into it. Thanks
   / Starter for Allis Chalmers HD-3 or D-15 Diesel #7
Measure the outside diameter of your bendix gear then do a tooth count, the 2/71 in the HD would have had a CW starter. The problem with the Allis number is that it would have been proprietary to their parts book and not that of Delco.who actually manufactured the starter.
I once had a Lincoln portable welder with the 2 / 71 engine and I'm sure that engine had many other applications, I would go with the most recent and popular piece of equipment in which the starter would interchange and use that as my part number.
On our forestry skidder that came with a 4/71 it had a 12 volt starter we changed to 24 volt for easier starting in cold weather. We don't like either.
The highway tractor that I borrowed to get my CDL had a 6/71 equipped with an air starting motor
Rotation and tooth count, the nose cone if the bolt pattern is different most will swap over to most delco made heavy duty starters.
Vane and Turbine Air Starters for Engines | by Ingersoll Rand | AirStartersDirect.com
   / Starter for Allis Chalmers HD-3 or D-15 Diesel #9
I have a 1961 HD-3 and just bought a new starter, part number 1107502 on ebay 9seller urqualitysolutions hope that helps
2012 ford f550 service truck (A52377)
2012 ford f550...
2015 FREIGHTLINER CASCADIA (A53843)
2015 FREIGHTLINER...
2019 Doosan LCV6W Towable LED Light Tower (A54811)
2019 Doosan LCV6W...
UNUSED EINGP MSC2030F 20' X 20' ALL-STEEL CARPORT (A54757)
UNUSED EINGP...
2023 New Holland CR10.90 Combine - 332 Engine Hours - 244 Separator Hours (A55302)
2023 New Holland...
2015 FORD F-150XL SINGLE CAB TRUCK (A51406)
2015 FORD F-150XL...
