Starter Armature
/ Starter Armature #1
sugargrovefarmer
Sugar Grove
Farmall Super M
52 Super M Farmall, Starter armature turned on a lathe until groves are gone, Will that cause the brushes to try and weld themselves to the surface when the starter is engaged and will regroving the armature solve the problem?
Any suggestions?
/ Starter Armature #2
so no mica insulator left either?
/ Starter Armature #4
Well at the risk of sounding stupid, What is the mica insulator?
Nor stupid , just an honest question.
The armature has a segmented commutator that use mica as an insulator between the segments. Mica is a naturally occuring mineral that is semitransparent (I believe it's a silcate). Before the advent of high temperature glass, it was used for windows on furnaces and wood stoves etc . It's an electrical insulator also.
/ Starter Armature
Well! Thank you very much, Do I replace the comutator? If so is there a good source for just the comutator or do I replace the starter?
Thank you!
/ Starter Armature #7
Each segment of the com should be separated by a thin strip of mica or similar material. After turning these strips should be slightly undercut so they don't keep the brushes from making good contact with the com....
/ Starter Armature
Now it makes sense, Man what an education, Now the next question is can a shop that rebuilds starters do the undercutting?
Thank you very Much!
/ Starter Armature #9
a broke hacksaw blade can do the undercutting! only needs to be like 1mm or so.. just to keep the brushes from riding up...
PALLET OF COTTON MACHINE PARTS (A63291)
PALLET OF COTTON...
KUHN SR108 GII 8 WHEEL SPEEDRAKE (A63291)
KUHN SR108 GII 8...
Caterpillar Scraper Parts Books (A63117)
Caterpillar...
12-16.5NHS Skid Steer Wheels and Tires (A61572)
12-16.5NHS Skid...
2018 International LT Automatic Day Cab (A62613)
2018 International...
(1) UNUSED 320/70R24 TIRE W/ 8 LUG RIM (A64280)
(1) UNUSED...
