Started my welding class am looking for a project
   / Started my welding class am looking for a project #1
pequeajim
Platinum Member
New Holland, PA
Power Trac 425
I just started an Intro To Welding class today. The class runs for 10 weeks of 6 hour classes, once per week. So as I learn, I am going to try to think up a project or two to do for my 425. I know one is a neat light bar that MR did for his 425, great idea!
Another is taking a trailer reciever and weling it to my blank mounting plate. I may even ask them how I can make a few duplicates.
Anyway, I was wondering if you guys had any EASY suggestions? /forums/images/graemlins/grin.gif
   / Started my welding class am looking for a project #2
Here is a picture of a ripper which can be mounted both ways.
Some welding and cutting is involved.
Who makes that?
   / Started my welding class am looking for a project #4
Sorry, but I don't remember. It is one of many that I have saved for reference. This ripper is offered by Metkit, to go on a backhoe, or mini-hoe, but could be adapted to the Quick-Attach plate. Looks like a good welding project. It is already cut and is ready for welding. If you have a drafting program, you can draft up one that is more in line to fit your machine.
I ordered one of their backhoe bucket, and welded it together, turned out nice,
Their log splitter looks pretty good too!
   / Started my welding class am looking for a project #6
I'd make some sort of multi-tool. Besides a reciever for a trailer hitch, I'd make some other items to slip into the reciever, such as a ripper, potato digger, slicer, cable layer, etc... just about anything you can think of to slip into the receiver.
   / Started my welding class am looking for a project #7
A small grapple rake would come in handy and involve lots of welding and cutting.
Eric
   / Started my welding class am looking for a project #8
</font><font color="blue" class="small">( Their log splitter looks pretty good too! )</font>
Hey,
This log splitter really does look pretty good. Does anyone have any ideas on how we might retrofit one for the 425?
Sincerely,
Rob /forums/images/graemlins/smile.gif
   / Started my welding class am looking for a project #9
I really like that concept. The cylinder is small enough that it might be ok to run it off the auxiliary Hydraulics. 7 ton would split some farley hard to split wood. Just turn it upside down and weld it to a Quick plate and two female disconnects and away you go. Very good find, I already have my splitter but I would have considered this one before. A good price as well. And roll the page up and check out the back hoe bucket out too. I do want one of those. Thanks for this link.
   / Started my welding class am looking for a project #10
It is $265.00, plus you have to weld it together, plus you have to supply the cylinder and all the hoses.
You'll have over $450 into it before making a quick attach plate. Probably closer to $500, not counting your labor and it doesn't do all that large of diameter log, only 10-12" is what is listed.
I would think you could pick up a chunk of I beam at a scrap yard pretty cheap to use as your base. Take some measurements from traditional log splitters and build one that is much heavier for the same cost.
As for adapting it to the PT, the AUX PTO is supposed to supply hydraulic pressure at 2500PSI but less than the 8GPM of the main PTO. You would have slower cycle times, but it would have enough pressure to do the job.
I like the idea of the splitter being upside down for use from the driver's seat. However I would also want to be able to rotate it 180 for manual loading. The problem then becomes, you would have to load a log and then move to the operator's station to operate the knee lever. That would be combersome.
I would add some sort of aux hydraulic circuit in parallel with the AUX PTO circuit and put a valve out on the splitter for manual operation as well.
2006 JLG 2030ES 20ft Electric Scissor Lift (A51691)
2006 JLG 2030ES...
Echo SRM2620 Gas Trimmer (A52377)
Echo SRM2620 Gas...
2012 INTERNATIONAL MA065 FLATBED (A52576)
2012 INTERNATIONAL...
JOHN DEERE 1705/6700 LOT NUMBER 20 (A53084)
JOHN DEERE...
LMC LOT NUMBER 139 (A53084)
LMC LOT NUMBER 139...
2017 John Deere 9620R Scraper Special Tractor (A53342)
2017 John Deere...
