Start problem
   / Start problem #1
Tarnold
Ellijay ga
Ls 3038h, ford 1900
Ford 1920 shuttle shift. Glow plugs will not turn off so disconnected, another problem. The problem for a long time
is starts fine, BUT if I stall it or shut it off, it will ONLY restart after about an hour cooldown.
   / Start problem #2
I`m not an expert, but it sounds as if you have a big electrics issue. Not restarting when hot sounds like the electrics cutting off the fuel pump until it gets below a preset temperature. Glow plugs sound as if they are getting a signal from the same bit of electrics. Some electronics, and again I say I do not know, but, sometimes if you take away all the power, sometimes electronic boards will reset to factory default when rebooting after a few minutes. But again I say I do not know. Good luck.
   / Start problem #3
I really don't know the 1920.... but here is the wiring diagram for the circuits in question... maybe they help.... Also we had an issue with the NH glow plug timer.... you can double check but I think your machine might use the same as ours... (NH part # SBA385870301 price $100+++) but it seems to cross over to a Kubota #15694-65990, which you can find for $25 or so...
2021 CATERPILLAR 259D3 SKID STEER (A51242)
2021 CATERPILLAR...
2008 INTERNATIONAL 4300 M7 SBA 4X2 DUMP TRUCK (A51406)
2008 INTERNATIONAL...
2016 Gravely Pro-Turn 260 60in Zero Turn Mower (A48082)
2016 Gravely...
AMCO F42B-3626CS 13ft Pull-Behind Wheel Offset Harrow Tiller (A49461)
AMCO F42B-3626CS...
2013 Ford F-150 (A50397)
2013 Ford F-150...
VOLVO L45G WHEEL LOADER (A51242)
VOLVO L45G WHEEL...
