Start it or leave it for spring
   / Start it or leave it for spring #31
Hang on....
Maybe I am confused by your upside down seasons :)
OP say it has 20 hrs on it ?
it has been since summer doing nothing & wait till spring, that is not 3 months, coming closer to 12 ?
It also seems to me, that when it does get used, it will be very little.
I start and run and warm everything, multiple mowers, ride on quads vehicles, tractors saws etc etc, if you do not, apart from the 2 stroke non battery electrical start stuff, your doing the machine no favors & the more complex the machine, the more it needs oil moving, brakes used, clutches, seals etc etc
People who do this sort of thing and leave stuff will be buying new batteries all the time, buggering around trying to get things going when they need them instead of being able to just use them, lack of use is worse than use.
The saving grace is that it has not done much work yet, and the period it has sat means battery already has damage.
People ......"will be buying new batteries all the time"
Really?
I leave cars, trucks, boats, tractors, mowers unattended for 6 months each year.
I am NOT.... "buying new batteries all the time".
I use Battery Minders/ Tenders/ etc., and my batteries usually last at least 8 or 9 years.
   / Start it or leave it for spring #32
The battery will not be the only issue. Clutch plates stuck, water in fuel, dry rot on tires. If it had been set up for storage, I would say leave it. If you do not have the time to get it started, run it, and correctly store it, leave it. If you have the time, to replace/charge battery, check fuel, and run it for about 2 hours, moving it, then do it. And then do things to store it.
   / Start it or leave it for spring #33
I would leave it and take a battery charger with me when I go up next time thinking I would need it.
My guess is the battery will be fine.
I let equipment set for months and only get a few hours a year on some with no real problems for years.
   / Start it or leave it for spring #34
I let my truck sit for 9 months.
It’s on the lift now waiting for the brake rotors, calipers, and pads to arrive.
I have had steering tie rod ends seize after extended storage, throttle linkages seize, and clutches stick.
Those road building equipment pieces will likely have the maintenance crew spend a day or more freshening things up before the next operator jumps in the seat to start moving earth.
   / Start it or leave it for spring #35
My truck sits sometimes 1 or 2 months between use.
   / Start it or leave it for spring #36
Clutch plates cannot stick if you "block" the clutch.
   / Start it or leave it for spring #37
How many people on the site, block their clutch? I bet very few. And most clutches do not stick.
I had a friend that sold a dozer that was 30 years old and very low hours. He wanted almost new price due to little use, kept under cover, etc. He was starting it about every 6 months for 15 to 30 minutes. When he did sale it, it went for about half of what he wanted. It setting did more damage than running it.
   / Start it or leave it for spring #38
I block my tractor clutch over winter.. I keep the block of wood in the toolbox.. it takes what 15 seconds to put in after washing and greasing in fall, its like Power Service in the tank cheap insurance.. I can't afford the "should of would of could of.."
   / Start it or leave it for spring #39
I see my problem, I don't wash mine.....ever.
Well..... I did once. One of them.
Thats why my tractors don't last.... 30 years outside, not washed, not waxed, clutch not blocked, I just don't do anything right.
   / Start it or leave it for spring #40
Outside of cleaning radiators, etc., I don't think washing a tractor extends it's life or shortens it.
In regards to modern tractors, those with lots of electronics and plastic, the best thing an owner can do is protect it from the sun's rays when not in use.
2013 Ford F450 4x4 Crew Cab Little Beaver LS300 Drill Rig Truck (A55852)
2013 Ford F450 4x4...
Rooster Weathervane (A55853)
Rooster...
2015 Peterbilt 337 Pac-Mac KBF-20H Forestry Grapple Truck (A53422)
2015 Peterbilt 337...
2017 VOLVO VNL64T670 TANDEM AXLE SLEEPER (A57880)
2017 VOLVO...
2001 WELLS CARGO 8' X 32' TOY HAULER DBL AXLE TRL (A57192)
2001 WELLS CARGO...
2010 Ford F-750 Stellar 10621 10,000LB 5 Ton Crane Mechanics Truck (A51692)
2010 Ford F-750...
