start hiccup
   / start hiccup #1
bailbud
Canyon BC
CK25
got 07 ck25 a little over 1000 hrs went to start today ,would start then stall then start then stall then run fine .what does this sound like . when it stalled it almost seemed like the key was shut off . injection pump ??
   / start hiccup #2
Could be early stages of fuel gell.
   / start hiccup #3
Did you try cycling the pre - heaters twice ? How cold was it ?
   / start hiccup #4
Sounds like fuel delivery problem, with possible "gelling like Magellan" :) You might take the fuel filter apart and check/clean the element in some kerosene. Look for a waxy buildup in the filter. Treat the fuel. and try again.
   / start hiccup #5
Got a dk55 that did the same thing it was a bad key switch
   / start hiccup
was warm out so i don't think fuel gel, it even did it after I ran it for awhile. will have to try it again and see if it does it again
   / start hiccup #7
My CK30hst did that when it was about 50'F so I knew it wasn't the fuel jelling. For me it was the ignition switch. I put in a new one and no problems. The switches are know to have the factory lube on the contacts get hard and get some dirt in them. Other members have cleaned theirs with good results. Some just use fluid film, WD-40, or something similar. You could try electric motor cleaner or brake clean which will clean and dry up followed by some type of lubricant. There's always the possibility that it could be the injection pump but I'd clean and lubricate the switch first. Much cheaper and may fix the problem.
2019 HONDA PIONEER 5 1000 UTV (A50459)
2019 HONDA PIONEER...
2019 Ford F550 4x4 Bucket Truck with Altec AT41 Boom - 46FT Working Height and Jib Winch (A51039)
2019 Ford F550 4x4...
2014 Ford Taurus Sedan (A50324)
2014 Ford Taurus...
FORD COBRA REPLICA RACING CAR (A51222)
FORD COBRA REPLICA...
2015 INTERNATIONAL 4300 26 FT NON CDL BOX TRUCK (A51219)
2015 INTERNATIONAL...
2013 PETERBILT 367 DAY CAB (INOPERABLE) (A50854)
2013 PETERBILT 367...
