Start Capacitor
/ Start Capacitor #1
BillyP
Eagletown, OK
JD 4610 ehydro MFWD
Can you safely substitute a 72-87 microfarad capacitor with a 88-108? It's on a 1HP belt drive fan motor. I've read you can safely go up one size as long as you stay with the same voltage rating or higher.
Thanks
/ Start Capacitor #2
As long as you are going up and not down, you should be fine. Those capacitors are typically rated as +80%/-20% anyway.
/ Start Capacitor
Just noticed that the new capacitors I was looking at are rated 125 VAC and the old one is 165 VAC. The only problem there is if I move up in voltage, so does the physical size of the capacitor. I can go a little longer but not in diameter.
/ Start Capacitor #4
You should not use a lower voltage rating capacitor. Different manufacturers often make capacitors with the same rating in different physical sizes so if your supplier does not have one that will fit, try another supplier.
/ Start Capacitor #5
What is the voltage of the motor? Measure the voltage across the capacitor. If it's less than 125V you are ok.
Keep in mind that the first cap failed for a reason. I usually go up in voltage and heat rating so that I don't have to ever fix it again.
/ Start Capacitor
The fan motor is 220 volt. That's what is confusing me. I have a 1.5hp motor that uses a 189-227MFD 125VAC start capacitor. The 1hp uses a 72-87MFD 165VAC capacitor.
These motors start every 5 minutes, 24 hours a day. I figure that might be the cause of failure? Do they make a heavy duty capacitor?
How do you go about measuring the voltage across the capacitor? They have three wires, one on one pole and two on another.
Another thing, the capacitors are rated at 65 degrees C. There's no way they ever reach that temp because they're pulling inside cooler air over.
/ Start Capacitor #7
You can go up in voltage and heat rating. Although it would seem that you are ok on the heat at 65C if the motor and cap are well ventilated.
Measure across the legs of the cap to see what voltage is across it. It sounds like the cap is wired across 220V. Which does not seem right for a cap rated less than 220V
Unless we are talking p-p and rms values......:confused:
I am hoping someone with more motor experience will jump in now.
/ Start Capacitor
I finally found a place to order them, thanks to Grainger. The sad thing is because they're 165VAC the price is 9 bucks a pop instead of a 125VAC at 4 bucks. Oh well....
Thanks a bunch
PS
If anyone comes up with a heavy duty/cycle capacitor, let me know.
Bush Hog 3008 (A64127)
2020 CHEVROLET SILVERADO CREW CAB TRUCK (A59823)
2020 CHEVROLET...
NEW ATS Mini Ride on Skid Steer (A62679)
NEW ATS Mini Ride...
2010 Ford Crown Vic (A62679)
2010 Ford Crown...
2005 John Deere 4110 (A64126)
2005 John Deere...
New/Unused 72inch Quick Attach Rock Grapple Bucket (A65583)
New/Unused 72inch...
