Starlink
/ Starlink #4,181
Starlink is driving me crazy lately. They keep switching my ground station from Los Angeles to Seattle. Then back. Then switch again. And so on.
Everytime they switch ground stations, Hulu Live TV quits working. Hulu is required as part of their content agreements to verify locations they stream to. Their first level support always asks for an IP address from ipchicken.com, then exclaims: You are not in Nevada, you are in Seattle!!!
First level support at Hulu doesn't work, so I always ask for a supervisor. A friendly supervisor advised in the future, say these magic words: "I have had a Starlink IP change, and I need an address override."
Live TV was out again this morning-- I was switched overnight back to Los Angeles. Called Hulu, said the magic words, and within 2 minutes I was back up and running.
If you use Hulu Live TV, i suggest trying the magic words. For me it cut the service phone call down from 20-30 minutes to a quick response.
btw, to try to get a Northern Nevada IP address to give them, I put my phone into airplane mode, turned off wifi, waited a few minutes, then exited airplane mode. Did an IP check and Verizon first served up a Lodi, CA location. On 2nd try, a Bakersfield, CA location. While I am sitting in Northern Nevada.
/ Starlink #4,182
Hulu is picking off the location from the IP lookup and that's a common failing. It will keep failing because a) the ground station can change, and b) Starlink does intentionally change the IP addresses of their gateways. The latter is a security feature, and not a bug in my view.
There is a setting on the Starlink router to makes the Starlink's actual GPS location available to devices being served by it. I don't know if your Hulu device can use it, or will believe it.
If it happens too often, you could put Hulu onto a VPN that surfaces some place stably, and use that as your address...
All the best,
Peter
/ Starlink #4,183
All the best,
Peter
Were is this setting?
I have never seen it while going through the various menu's.
/ Starlink #4,184
A bit ironic that although many use a VPN to spoof a fake location so they can get live TV in a different market, such as for sports, I might instead need to use a VPN in reverse-- to "spoof" that I really am sitting in my living room!! 😀
/ Starlink #4,185
It is a bit hidden. Here are the secret handshakes to get you there;
Scroll to the bottom of the first page, where it says
"STARLINK NNNN.XXXX. ADVANCED" and click on "ADVANCED", then scroll to the bottom of that sub-menu, where it shows "Debug Data", and click on "Debug Data", then scroll to the very bottom of the debug information, where there are two sliders/toggles. The location information is the bottom one, "Allow access on local network". Turn it on, and local devices can get the GPS location from the Starlink dish.
I don't know what devices would/could access the GPS information. Per this Reddit thread, it responds to a grpc query from local devices;
All the best,
Peter
/ Starlink #4,186
It is a bit hidden. Here is the secret handshakes to get you there;
All the best,
Peter
Thanks, switched it on will see how things go and if anything changes.
/ Starlink #4,187
Not sure if this has been posted before.
Interview by Ellie in Space concerning the new mini Starlink that can fit in a backpack also commentary on Starlink losing out on rural broadband contract.
Now being offered for order, initial roll out only offered to a limited group. Full roll out in July.
The mini dish has an on board router
/ Starlink #4,188
I live in a area that does not have Starlink available yet. I am considering getting Starlink Roam & then converting to home when it becomes available. Can anyone with the Roam version give me their download & upload stats? I know is is less than home, but the critical question is how much less?
/ Starlink #4,189
That's how I started, was called RV version then. I didn't notice much difference once I got the home version, was way better than anything i had before.
/ Starlink #4,190
I have two SL residential systems and a SL "RV" system (is it renamed roam?)
I can't say I've ever seen much difference, but part of that is SL speeds vary constantly.
Also, not to be difficult, but I don't think anyone can answer your question. It's my understanding that these systems are dependent on other traffic in your particular area. So what's going on in areas away from you might be quite different than your experience.
I wouldn't let the speed dissuade your purchase-- I've always had plenty of speed for my needs in all circumstances.
Kubota MX5400 land mgmt package
Kubota MX5400 land...
2019 KUBOTA KX033-4 EXCAVATOR (A60429)
2019 KUBOTA...
WOOD GRABBER FOR MINI EXCAVATOR (A58214)
WOOD GRABBER FOR...
2019 INTERNATIONAL DURASTAR 4300 BOX TRUCK (A60736)
2019 INTERNATIONAL...
2017 FORD F-550 SERVICE TRUCK (A58214)
2017 FORD F-550...
1999 CHEVROLET C7500 UTILITY TRUCK (A59906)
1999 CHEVROLET...
