Starlink
/ Starlink
This video shows setup, and shows the look angle (in Oregon) It痴 pretty high on the horizon.
Starlink Setup and Testing - YouTube
:thumbsup: Appreciate the useful link. Unfortunately it assumes customers own a smartphone to run the "app". Believe it or not there are still a few rural folks on this planet who aren't smartphone owners. :)
/ Starlink #724
Especially if you can't get cell reception. We used to have to walk up to the end of the drive, to get really crappy reception.
/ Starlink #725
I still have the good old fashioned flip phone which goes along with our poor cell phone reception.
/ Starlink #727
You don't need a cell signal or a WiFi connection to use the app in "Check for Obstructions" mode. (I just put my phone in "Airplane mode", which shuts off all those connections, and the obstruction check still works. I believe (but have not verified) the app needs to have some idea of where you are, but if you have a view of the sky, the GPS in the phone will correctly locate you, even without a cell or WiFi signal. IF your sky is so obstructed that you can't get a GPS signal, odds are that Starlink is not going to work for you.
If you don't own a smart phone, you have a couple of options:
  1. Ask a friend with a smartphone to download the app and come over to spend a few minutes helping you find a location
  2. Eyeball the location. More sky visibility is better than none. If you want to do better than just an eyeball look, bring out a protractor or anyting that can measure angles. From Starlink's FAQs: "In early service, the required clear field of view is a 100-degree cone around the center of the dish (after tilting)". That's 50˚ on all sides around the center of where the dish chooses to aim itself. In my part of the country, Starlink dishes tilt about 15-20˚ to the north (just eyeballing it). So the cone needs to be centered around that tilt. The size of the needed obstruction-free cone will shrink as Starlink launches more satellites - it may already be smaller, since that number was fro the early days of the Beta testing. If I get time, I'll go out and measure the size of the cone the app recommends in my area. Obviously, the easier way to do this is option 1: invite a friend with a smart phone over.
When I set up mine, I walked into the space between my 2 story house 45 feet to the NE, a two story garage to the north, some tall trees 60 feet to the SW-W, and some more trees to the SW-S-E but those are either smaller or further away. The top of a young maple 20' to the south was just barely a problem by the time I go far enough away from the house and garage, so instead of putting the dish on the ground, I put our picnic table in that spot and screwed the base of the dish to it. Once the system is up and running, it builds a map of obstructions and tracks how much signal loss is due to obstructions. I can't tell you what the report looks like when you check it in the app, because mine just says "Not Obstructed. All good! Starlink has not been obstructed recently."
The app also reports statistics once your system has been up and running. Mine reports that in the last 12 hours, we lost signal due to no satellites in view for a total of 27 seconds. We lost signal due to "Beta Downtime" (planned outages for upgrades/updates) for a total of 5 minutes in that 12 hours.
I've had 2+ hour Zoom meetings recently where the only issue was a couple of 1 second "stutters". This is improved from when we first connected a couple of weeks ago, where I'd get briefly disconnected, the reconnect 5 or 10 seconds later.
/ Starlink #729
The tear down videos show the antenna has a GPS receiver in it.
Most system setups today are web server based , so you can probably set up using a regular pc on the Ethernet port. My speculation.
/ Starlink #730
The guy on CrossTalk Solutions did a speed test on his laptop, and thought he could do better if he moved the dish, what i guessed to be is a southern direction, because he thought his house might be impinging on his satellite "view". Sure enough, he got better speed.
/ Starlink #731
Anyone getting shipping notice after putting $99. down and if so where are you located? Just wondering if they are moving south any .
/ Starlink #732
I was told mid to late 2021.
/ Starlink #733
When I got the e-mail on 2/8 it implied they were available in my area, not a pre-order or deposit. When I checked availability by my address it came up with an order page for the full cost of the hardware package ($499 + shipping/tax). I originally was going to pass on it and hope for more availability in spring because it's winter here in MN and there isn't a great way to get on my roof or place it in the lawn well. But changed my mind this week and placed the order. Order confirmation said it might ship in 4-6 weeks due to 'increased demand'. So I guess when it arrives winter will be mostly over. Crossing my fingers that this works out because Internet options in rural MN where I live are quite limited.
Rob
/ Starlink #735
SpaceX launched 60 more satellites Monday night.
/ Starlink #736
Rob
It's been working great for me for over 2 weeks now - major snow storm did not affect coverage at all. As a temporary set up, mine is screwed to the picnic table in my side yard with the cable running in a window that is slightly opened (with foam and weatherstripping to plug the cracks). It has just enough of an opening there to get good coverage. When the weather gets nicer, I'll put it up on my roof and do a permanent cable run.
Very happy with the performance so far. I got up before others got on this morning to run a speed test: 201 Mbps down, 27 Mbps up with 35 ms latency. I've done several Zoom conferences over it that have worked well, even with my 2 kids each streaming YouTube at it's highest resolution at the same time.
The Starlink smartphone app has a feature that tells you recent performance statistics. Over the past 12 hours, it's been down for 11 seconds due to "no satellite coverage, and 4 minutes due to "Beta Downtime" (which I gather is planned downtime as they tweak software or make other adjustments). Bot of those numbers will drop as the number of satellites increases and the system matures.
/ Starlink #737
Can the antenna be "pole mounted" like our present Excede Dish?
Our roof is standing seam metal and I'm not inclined to make any additional penetrations in it.
/ Starlink #740
Yes, they make an adapter for that:
Starlink
I'm debating whether to get that and mount to the old (no longer used) DirecTV dish mount that's already on my roof or just get the roof plate (Starlink) and mount it that way. The DirecTV post is in a great spot and I wouldn't have to drill but it is exactly on the opposite side of the house from where the router/control will be so I may have cable length and routing issues.
Rob
2019 Freightliner M2 106 AWD Altec DM47BTR Insulated Digger Derrick Truck (A60460)
2019 Freightliner...
2019 CATERPILLAR TL642D TELESCPOPIC FORKLIFT (A62129)
2019 CATERPILLAR...
E-Z TRAIL 3400 SEED TENDER (A63291)
E-Z TRAIL 3400...
2019 PETERBILT 567 TRI/A DUMP TRUCK (A59912)
2019 PETERBILT 567...
2007 MACK CTP713 TRI AXLE DUMP TRUCK (A59575)
2007 MACK CTP713...
TPL MECHANICS BODY LUBE SKID (A60429)
TPL MECHANICS BODY...
