Starlink
/ Starlink #4,861
I'm considering Starlink at my place. There is really no reliable wired or fiber internet available for my location. I currently get it over the air with a line-of-site receiver on the side of my house. I usually get between 40-50 MBPS but it drops out often enough that it's annoying. My biggest concern is with it being installed on the roof. I really don't want any holes through my shingles, but it sounds like that's the only option. Do any of you have any input on that?
My neighbor just lays hers on the lawn. moves it when cutting grass and puts it back when shes done or when the wind blows from the east.
/ Starlink #4,862
I had the first oddity with Starlink this morning. Our power went out for about an hour and a half. When it came back on I had to reconfigure Starlink's wifi. I set it up with the same network name and password and everything connected as before. I have never had to do that before.
/ Starlink #4,863
I hope I never have to do that. I have my star link router and TV on a UPS from APC 1100
/ Starlink #4,864
That's weird. Ours has been subject to more than a few glitches and I have never had to do that. I hope it is just a one time thing for you.
All the best, Peter
/ Starlink #4,865
Excellent note. In December my Gen2 Dishy permanently failed to reboot after a software update. It was replaced with a Gen3. It's a technical AND power improvement over the Gen2 but uses no more 120vac power in service. Power from a UPS would cover most outages that grid reliant folks would experience.
/ Starlink #4,866
My starlink router and the wifi router (ported starlink) are on a UPS power device to prevent these kind of issues. Display estimates a 125 minute backup. This, plus whole house generator means….no issues. I also got tired of my main TV having to go thru long reboot after outage or power glitch, so I have a UPS on the tv also. It’s weird to be in a house at night and all the lights go out, but tv is still playing movie. 15 seconds later everything is back up and running on generator, still watching movie and wife is still searching on iPad. We get a lot of outages here in the sticks.
/ Starlink #4,867
Received this email from Starlink about a week ago, it does sound interesting​
Starting at $50/mo for Fast, Reliable Internet​
Get up to 400+ Mbps speeds
Starlink is offering new Residential service plans delivering high-speed internet designed for every need:
New Residential Plans​
  • Residential 100 Mbps: Reliable, affordable home internet service for seamless connectivity with speeds up to 100 Mbps. Select areas.
  • Residential 200 Mbps: Fast, reliable internet service for everyday home use with speeds up to 200 Mbps. Select areas.
  • Residential Max: Our best performing home internet service with maximum speeds available—up to 400+ Mbps. With this plan, you can opt in for a free Mini Kit with flexible, discounted service plans to use while traveling, camping, boating, RVing, and more in 150+ markets.
See speeds in your area here.
Explore internet designed for every need
Speeds are not guaranteed and based on global 99th percentile download speeds. Pricing and plan availability may vary based on location.
/ Starlink #4,868
Those changes were posted here in this thread about two weeks ago, btw.
/ Starlink #4,869
We lost power again last night but it came back up knowing who it was. I definitely need to put it on a UPS, call it procrastination.
/ Starlink #4,870
What did that manifest like? Did it come up on its own with the default wifi name, as if it had been factory reset during/by the outage? Or did it not boot after the power loss and you had to force a factory reset to get it up again? Or some other situation?
/ Starlink #4,871
FWIW: Starlink will do a factory reset for just the right sequence of
ON/OFF/ON/OFF/ON...
So power outage that did not fail gracefully, e.g. with a tree branch shorting it out repeatedly on the way to taking it out might trigger the factory reset.🤷‍♂️
All the best, Peter
/ Starlink #4,872
It just did a reset. I knew what happened when I saw Starlink in my wifi list instead of my wifi name. I just joined it and went to the Starlink app to set it up again. As long as you set it up with the same wifi name and password everything on your network connects back as before.
/ Starlink #4,873
My Gen 2 system stopped working. I contacted Starlink, they immediately shipped me a refurbished Gen 3.
I believe the Gen 3 has stronger wi-fi. Setup was simple. Only issue is I have to add a pipe adapter.
Gen 3 has a couple of Ethernet ports so don't need the Ethernet adapter I had to buy for the Gen 2.
I'm very happy with their Customer Service.
/ Starlink #4,874
That's a nice upgrade. I always thought it was unfortunate that it required extra adapters to run/keep your own wifi network
/ Starlink #4,875
My exact experience but out of frustration I bought a replacement from Home Depot. In the end they fully credited the cost. I'm not sure if this is a standard or recommended action. But Elon, the a*****'s company, did us right.
I am a dedicated customer. And they know I have no other options for service including cell. How often does that happen?
/ Starlink #4,876
Does the Gen 3 system work with the Gen 2 cable? It will be a real pain for me if I have to replace it.
/ Starlink #4,877
No. The cables are different. The default gen 3 cable is a little shorter, but there is a longer one as an option. Personally, the gen 3 are closer to industry standard cables, so I like it a bit better.
Redoing the cable wasn't pretty here either, but the increase in performance was great.
All the best, Peter
/ Starlink #4,878
Just put up my Gen 3 On Monday. Will be a week tomorrow and Love It so far. Mounted on my old tv antenna tower to get a clear shot of the sky was the hardest part due to snowy roof but set up was easy. Waiting for my mini now for the 5th wheel so we can have internet when camping. Real happy so far.
/ Starlink #4,879
I've been a week with fiber at the new home. Loving it!
I have my Starlink from our old place all boxed up. I guess I can sell it.
/ Starlink #4,880
Congratulations on getting working fiber!
If it were me, I wouldn't be in a big rush to sell the Starlink, at least until I had some sense of the new ISP/fiber and its uptime/reliability, but connectivity is important here. It may not be an issue for you.
All the best,
Peter
