Star head screws
/ Star head screws #41
Robertson is just a square drive IIRC.
While they are better than Phillips by a lot, I don't think they are as good as torx.
Another type out are spline drives. Slot of structural screws are using them. While probably stronger and less likely to strip out than torx, for wood screws I don't see a practical advantage.
/ Star head screws #42
The metallurgy of Torx bits from some suppliers can be questionable for sure. The cam bearing caps on Triumph 900cc triples are notoriously tight and there are numerous stories of bits snapping off and leaving brittle tool-steel shrapnel inside the engine where it is difficult or impossible to extract. I bought a set of the 3/8" drive ones made by Lisle. Good so far!
/ Star head screws #43
The Torx heads are great for automated machinery. Hex heads are awful. That is the main reason that Torx heads are being used in automobile assembly.
I have always sworn at Robertson heads. It seems that I strip a lot more of those than that Torx.
/ Star head screws #44
I love em over even the square drive screws. in order of preference torx, hex (allen), square drive, phillips then common slotted which should be banned from the face of the earth then phillips drives should be done away with.
We could probably do without some others, too.
Bruce
/ Star head screws #45
Great chart. I have one to add. I have a box of #8 self drilling/self threading metal screws. They have hex head on the outside and torx on the inside.
/ Star head screws #46
Haven't seen those.
Do you prefer to use the hex, or the torx?
I find a good magnetic nut driver works well. But have never had the pleasure of using torx drive for a sheet-metal screw. Only wood screws and the larger automotive fasteners
/ Star head screws #47
A few facts on Robertson Screws. It would seem he introduced the recessed head screw back in about 1908. Lots were used on Model T's but stopped as Henry wanted controll of manufacturing but did not get it!
[video]http://www.robertsonscrew.com/history.html[/video]
/ Star head screws #49
Nah, there's only one sizing spec - Torx - Wikipedia
But there is now "Super Torx".
I was wrong on this - "Super Torx" is just what Lisle (and maybe some others?) call their high-quality "regular" Torx bits. What I meant to say is that there is now (since 1990), "TORX PLUS".
"A Torx successor, Torx Plus, was introduced about 1990 when the original Torx patent was expiring. The lobes are more square to allow for higher torque and to minimize wear. The name is shortened to IP (Internal Plus) with sizes ranging from 1IP to 100IP [16] (sometimes listed as IP1 to IP100 [17]) and EP (External Plus) with sizes ranging from 1EP to 42EP as well as smaller sizes ranging from H7EP to H2EP and includes five-lobed tamper-resistant variants.[16] The specifications for these licenses are held by Textron. Standard Torx drivers can be used to drive Torx Plus screws, but not to full torque because of the loose fit. Torx Plus drivers will not fit into standard Torx screws."
(From Wikipedia, emphasis added by me)
/ Star head screws #51
Are you sure you are using the original Robertson or the American copy that looks the same but isn't?
[video]http://www.instructables.com/id/When-a-Phillips-is-not-a-Phillips/step6/Square-Drive/[/video]
/ Star head screws #52
I hear you, Egon, original have deeper holes and even a tapered bottom while the cheap 'offshore' copies are shallow.
Also the 'offshore' copies are so soft that the square hole soon becomes round.
A real quality Robertson can actually be held on the driver bit at even less than level to ground.
/ Star head screws #53
Not sure. I bought them at Home Depot in Windsor, Ont when I lived there.
/ Star head screws #54
I noticed another screw head not on the chart. It is called double-square. I ran into them when I had to replace an aluminum panel on a Haulmark trailer. You can get eight point driver bits but a regular square bit fits too.
/ Star head screws #56
This has become my favorite website.
Where else can you get 55 posts on something as riviting as screws?
Gotta love it,and thanks
/ Star head screws #57
As riveting as screws?
As screwy as screws!
Bruce
/ Star head screws
I'd recommend marking "BOTTOM" (or, "OPEN FROM OTHER SIDE") on the bottom! :D I care more about being wrong (if you're going to help steer someone sometimes the best is to tell them WHAT to avoid :D)
Good idea!
2024 Polaris Sportsman 570 AWD ATV (A64557)
2024 Polaris...
2008 PRESVAC HYDRO BLASTER (A59914)
2008 PRESVAC HYDRO...
2006 Generac SD0150 187kVA T/A Towable Diesel Generator (A61572)
2006 Generac...
26 ft trailer 20 ft bed (A61567)
26 ft trailer 20...
Quick Attach Backing Plate (A65579)
Quick Attach...
2022 EZ-GO ELITE...
