Comparison Standard vs premium tractors
   / Standard vs premium tractors #52
Sorry for the double post (meant to edit to use a different picture and got messed up).
   / Standard vs premium tractors #53
ok, but if your nose is growing longer, I called it...
you know way more about tractors than you let on. ;)
Stop picking on my nose:D. Lots of brands make smaller machines. I thought it might do something really cool.:)
   / Standard vs premium tractors #54
murphy, do you know of another small-framed 30hp machine? Just curious...
But, for a small fee I'd show you videos of the real tricks that it can do:D (I have to recoup my training expenses ;))
   / Standard vs premium tractors #55
kioti ck series, bobcat 230,235,225. I am sure new holland and deere have something.How much for videos?
   / Standard vs premium tractors #56
Doesn't Deere have a feature leg up with their AutoHitch arrangement?
Granted only on SCUT/CUT; always wondered how that pto shaft hookup arrangement worked.
reminded me of inflight fueling for aircraft. Wonder how it holds up to repeated near misses.
Now that to me is a very premium feature, particularly if no one else has it.
   / Standard vs premium tractors #57
Bobcat 230 (I'm assuming the others are similarly spec'd) is wider (2 1/2") and doesn't have as much ground clearance (5 1/2"). And if you need less weight (such as driving into small buildings like I did)...
The Kioti CKs are close, but still just slightly bigger (and weigh more; note that I don't have anything against weight- adding ballast to the B7800's rears was a godsend). And now that I'm a Kioti snob :)D) I appreciate the CKs: I looked at one while hanging around the dealer's and was really impressed with it.
The ground clearance is a big deal here. I've four-wheeled the B7800 (literally climbing on top of all sorts of brush). Yeah, folks poo-poo such behaviors, but this machine has done a lot of it and I've had very few issues of problems stemming from doing it!
The B7800 was built to be beat. Targeted for the commercial/rental market (my understanding). If I could beat my new Kioti like I've done with my B7800 (and get away with it) I'd be in heaven! :D
How much?, you ask? If you have to ask then you can't afford it:laughing: (man, I've got pictures of stuff that I've done that I'd get in trouble for if I posted publicly! of course, the truly troubling ones would be the result of my activities with excavators :D)
   / Standard vs premium tractors #58
It did seem odd that the Deere doesn't have split brakes or a loader that is removable. How much are steering brakes useful with four wheel drive and a loader? I am leaning orange because all the plastic on the JD seems crappy and the plastic hood on JD lawn tractor will not go the distance. And my Kubota dealer is better.
Don't knock the JD plastic. I have a 15 or so year old L110 hydro riding lawn mower that I use for my "gator". I attached an old freezer wire basket (a big one) on the hood and into that loaded all sorts of things, paying no attention to weight....if I could lift it to get it in the basket it went. I can supply a picture if it's all that big of a deal. Possibly in sub zero climates, the plastic may be brittle but I'm not in one of those so temp is not a consideration.
On which; your money, your application, your decision. I opted for the lower price range Branson as I like their product line and don't need the customer support others may require that would direct them toward the larger dealer establishments that can provide services like on site regular maintenance activities...oil and filter changes, etc.
Then I opted for the decked out version for my main work tractor and just recently bought the lowest size/amenities model for my around the farm chores which only require the basic functions. Again, my money, my application, my decision.
   / Standard vs premium tractors #59
It is not quite 30 HP but a Mahindra Max28 is stronger than a B7800, but the HST is only 2 speed. If HST I pick Kubota, for 3pt and FEL capacity Max28.
   / Standard vs premium tractors #60
I reckon it depends primarily on your personal preference and for what application your doing. I didn't like the 3032 or 3038 for the reasons that the loader doesn't come off, there was no gear option, the aluminum rear end sounds scary, the differential lock built into the brake without individual wheel brakes and the rear wheels aren't adjustable. I have an older JD 4110 that I love and just got a Kubota L2501 that makes me happy. In the end, try what you think you like, do lots of research and buy whatever makes you happy.
UNUSED FUTURE XLA59 - 59" DRUM SPIKE LAWN AERATOR (A52706)
UNUSED FUTURE...
2017 Chevrolet Silverado 2500 4x4 Crew Cab Pickup Truck (A55973)
2017 Chevrolet...
2012 Vantage P-42-1000 42ft. T/A Dry Bulk Pneumatic Tank Trailer (A55973)
2012 Vantage...
SKID STEER ATTACHMENT MAINTAINER BLADE (A58214)
SKID STEER...
NEW Landhonor 9200LB Ratchet Binders & G70 Chains (A59000)
NEW Landhonor...
iDrive TDS-2010H ProJack M2 Electric Trailer Dolly (A55851)
iDrive TDS-2010H...
