Comparison Standard vs premium tractors
   / Standard vs premium tractors
A heavier tractor is a plus for me, to a point as I will be doing some loader work and moving round bales of hay on the loader and the 3 point.
For mowing a loader that removes/installs easily would be important IMO. (I nearly always mow with the loader off)
For me a SSQA (skid steer quick attach ) bucket is a must have on a loader.
That's what I was thinking. It seems easier on the front end to not bounce through a field with the loader on while mowing.
The SSQA would be a plus as my dad and I could go in together and share a grapple or other attachments.
   / Standard vs premium tractors #13
I know when I compare the Kubota Grand L to the standard L (which is what I own), I perceive a lot of extra benefit for the premium features, especially with regards to the HST sophistication. A standard L has been fine for my needs, but I would not flinch at paying extra for the Grand L's extras if my needs evolved in that direction. Generally you do get what you pay for with the premium models, so it comes down to whether or not you want or need those features. May come down to $$ versus features, which is a typical tradeoff for tractor shoppers.
   / Standard vs premium tractors #14
I have owned 5 tractors. Some simple "standard" tractors, some "deluxe" tractors. For me, I prefer operating the "deluxe" tractors. And the older I get, the more I prefer the deluxe tractors with their deluxe features, greater weight, additional hydraulic power etc.
I am not saying I didn't get good value and return on my money with the standard tractors, but the deluxe tractors are just better for me. But if all you need is the features of a standard tractor, the there is nothing wrong with that either.
   / Standard vs premium tractors #15
Premium tractors come with more options and creature features than a standard tractor. Unless you need those options a standard tractor would work fine for basic mowing and road maint.
Most standard tractor also come with power steering today. There's usually not much weight difference between standard and premium models and lift capacities are also the same. If you are seeing higher weight and lift capacities then the higher tractor is probably the next model up in the model line.
   / Standard vs premium tractors #16
Weather or not a premium tractor is worth the price difference is an IMPOSSIBLE question to answer.
Different features matter to different people. For some people, yes it's worth the difference. For others, no it's not. Thus they make, and sell a lot of both.
Differences also are typically more than just weight/performance/lift capacities. Things like better ergonomics, layout, better seat, telescoping lower links and stabilizers, better HST, electronic push button 4wd and PTO instead mechanical, etc etc.
Don't know much about the Deere's. But the Kubota....consider comparing the l4701 or mx5200 to the grand L line. You will get the bigger tractor, weight, and lift capacities. But without alot of the other things that make the grand L luxurious.
   / Standard vs premium tractors #17
Just remember that all those fancy features on some of the models are all electronically controlled and can be very expensive to fix when (not if) they quit working.
I would say, look at the tractor that has what you need on it and don't buy frills that you wont ever use.
As for split brakes, I wouldn't buy a tractor without them. I grew up on tractors with split brakes that were used in turning all the time. Even with 4 WD, you still get a lot of sliding when turning in wet ground and a little bit of brake pressure makes them turn without gouging up a path. Those that don't use them really are missing out on a good feature of a tractor. I never lock my brakes, my foot is big enough that I can put my foot in the middle of the two and press them both at the same time so why lock up a feature that you may need.
As for weight distribution, I don't think there is that much difference in 2 WD vs 4WD. Sure the front axle is a bit heavier, but the rest of the tractor is the same so Art's 75R/25F for older 2 WD is way off at least for bare tractor. Hundreds of pounds of rear wheel weights had to be added to each tire to get that ratio. I have seen 2 WD farm tractors with over 1000 # of iron ballast PLUS liquid filled on each wheel plus dual wheels just to get the traction needed. Add in all that weight and you may get the 75/25 ratio.
For 4 WD tractors with a FEL on it and no rear ballast, most of the pulling force is on the front due to the weight of the engine and FEL. Without some substantial rear weight and with it in 2WD with FEL installed it will barely pull itself on level ground and if on even a slight incline, it wont move up the hill (BTDT). I would say that pulling force on a 4 WD is about 70% on the front and 30 on the rear until you add a lot of weight for ballast to keep the rear wheels on the ground.
   / Standard vs premium tractors #18
Actually NOT impossible to answer. Every premium tractor, vehicle, computer, electrical device, tool, truck etc, I have ever purchased I but the top of the line. I always get my money back at resale. My last sale was buying the best "USED" 2006 CAT track loader at the time in 2008, with every option available. I drove that beast hard for 10 years and sold it for exactly $4,000 less than what I paid for it. Where else can you run a top of the line tractor for nearly 8 years and only cost you 4K. Anyone here that would rent a CAT track loader for $500.00 a year, that's what it came out to.
So my answer is always BUY the best sue it enjoy it and make your money back when it; time to sell. If you never sell, then YOLO, so buy the best as we all deserve it, and contrary to beliefs working a tractor for 8-10 is WORK, so anything to make work easier I'm all for that. I can also put a price n comfort, being cool when its hot and being warm when its cold, is pretty much worth A LOT to me.
   / Standard vs premium tractors #19
The standard L series and MX tractors have every bit as good resale as the grand L's.
And some never plan to sell so the resale value is irrelevant. Again, they make both, and sell alot of each. So for some, premium is worth it, obviously if that's what they bought. But there are just as many non-premium tractor owners. Who clearly felt the added cost of premium wasn't worth it.
   / Standard vs premium tractors #20
I suspect there are more standard tractor owners than premium tractor owners simply due to the costs. I don't have production figures to back this up, but judging by the number of people on this board that have standard Kubota's vs the number that own premium Kubota's I suspect more standards are sold.
2023 GMC Sierra 1500 4x4 Crew Cab Pickup Truck (A56858)
2023 GMC Sierra...
SKID STEER ATTACHMENT CEMENT MIXER (A58214)
SKID STEER...
2010 Chevrolet Silverado 1500 Ext. Cab Pickup Truck (A55973)
2010 Chevrolet...
20Ft. Bi-Parting Wrought Iron Gate (New/Unused) Galvanized + Powder Coated (A59225)
20Ft. Bi-Parting...
2022 Caterpillar 289D3 Compact Track Loader Skid Steer (A55973)
2022 Caterpillar...
2018 RAM 2500 (A58214)
