Stand by generators
   / Stand by generators #72
Disagree: A engine/generator set with capacity over that required is inefficient and at low loads damages the generator section.
I don't get it. Alll the dealers telll you to have enough juice to handle the (often huge) spike when fridges and the like come on, so I expect that most people's gens are running at less than half capacity. (Mine at the cottage is a 17 kw Kohler, because we have a hot tib.)
So what is the problem with lower
Loads?
   / Stand by generators #73
[/I]
Your right that your Generac is capable of running NG or Propane just by moving a lever on the carb. But I don't know if the regulator is the same for the two fuels. I do know the pressures are set different for them. If the regulator is compatible, all you need to have handy is a gauge to reset the pressure.
I know my regulator on my propane unit is different than the one for my furnace. I have 2 lines coming from the tank, one to the furnace, and one to the genny.
   / Stand by generators #74
I would expect to need a different regulator for propane....not a huge problem, but something to be aware of.
   / Stand by generators #75
I think the main issue is wetstacking (http://cliffordpower.com/wp/wp-content/uploads/2011/12/IS_09_[B]wet_Stacking_GENERAC.pdf), which is most known on diesels but can affect propane/NG engines too from what I have read. The main problem occurs if the generator is operating for short duration and light load and can never reach operating temperature.
[/B]
As far as efficiency, my 21kW diesel generator has an Isuzu engine, and it scales down fuel efficiency extremely well at lower loads, to the point were there is almost no penalty for running at lower loads compared to having smaller generators. This was unique to Isuzu units; the Kubota and Mitsubishi powered units do fare worse when running under light loads.
I don't think that would be an issue with any unit up to 20Kw (Generac that is), because they're all air cooled and warm up pretty fast. Now anything above that being water cooled might make a difference due to getting up to operating temp. Never thought about that before.
   / Stand by generators #76
Holy smokes, I pay $3.22 per gallon at the cottage! Where can I buy a big tanker semi of that stuff at $1.35?
Dealers here usually have late summer, early fall sales, $1.35 was the sept price. They also provide pre booking for winter delivery, that was $1.65 in sept. Works well for people that have smaller tanks and can't go all winter with out getting more. The local price two weeks ago was $2.10 so buying pre booked was a smart move this year.
   / Stand by generators #77
In Canada, everything is different. You can't shop for a supplier of propane.,.you are stuck with the one who gave you the tank. They all claim the system is safer this way... Uber regulation means high propane costs. (We went through 20% of our 325gallon tank over the Christmas holidays.... -20 will do that.). I called them asking them if i could just buy a tank instead of renting from them...the sarcasm from the customer service gal was funny...and these are 'the
cheers,
   / Stand by generators #78
Loads?
There is no problem running a generator with minimal load except for you could be wasting money on fuel by running an engine larger than needed.
   / Stand by generators #79
cheers,
We can either lease a tank to be serviced only by that dealer or buy one out right and be able to shop for the lowest area price. It's surprising how much the price will vary between dealers only a few miles apart.
   / Stand by generators #80
New/Unused CFG Industrial MX12RX Mini Excavator (A57453)
New/Unused CFG...
Golf Cart (A55787)
Golf Cart (A55787)
2018 Peterbilt 567 T/A McNeilus 2511 25Yd Rear Loader Garbage Truck (A55973)
2018 Peterbilt 567...
New Holland TS6.120 Power Shuttle 4WD 120HP Agricultural Tractor (A56857)
New Holland...
2018 LARK UNITED MANUFACTURING S/A GUARD SHACK (A58214)
2018 LARK UNITED...
New/Unused Electric Golf Cart (A57453)
New/Unused...
