Stand-by generator
   / Stand-by generator #1
Olmike
Holton, Kansas NO. of Topeka
case 1835 uniloader,720K grasshopper,76 F350 with dump bed,cushman truckster with dump bed
I've been puttin this together for about A month. The motor is A 2.5 chevy 4 cyl. out of an 85 cj5 jeep. My son gave me the motor cause he upgraded to A 4.3. The generator was originally powered by an onan water cooled 2 cyl And came out of a houseboat. It was given to me by my BIL. I got the propane stuff from a freind who had it in his basement,also for free.It puts out 6.5 KW.Total cash investment is less than $200.We ain't gonna count the time invested.It also has a DC output of 36 volts,I want to try to make a welder out of that part.If any of you guys know how that would I'd like to hear from you.
   / Stand-by generator #2
That's cool. You might want to measure the gallons per hour fuel consumption so you can be prepared with enough fuel. I suspect it will use a lot more than a gallon per hour. Still, for what you have in it, it's a good emergency generator.
   / Stand-by generator #3
I was thinking gallons per minute . :D :D
Actually it looks really good, especially for the price.
Is it running in the last pic or is that just a shaky camera? I sure wouldn't run it in an enclosed garage, even for a few minutes.
   / Stand-by generator #4
The price is great. Hope that your generator works as well as you expected.
Thanks for the comments. Dave, Yea it was runnin in the shop. I had the door cracked open & the exhaust fan On.The building is bigger than it looks in the pics. I don't what fuel consumtion will be,But for what I got in it I don't care if never have to use it. Even then it'll be better than sittin in the dark!
Mike
   / Stand-by generator #6
I don't know what the rated power output of that engine might be, but at 6.5KVA, you're only going to be consuming 12-15HP. My guess is that is a light load on the engine and the fuel consumption will be less than you expect.
You didn't say anything about an engine governor so I'd be more concerned with RPM/Voltage/frequency control. No big deal if all you're doing is burning some light bulbs, but it could get dicey if there are any motors, electronics, etc. in the load.
   / Stand-by generator #7
Does it have it's on propane source, or are you going to tie it in to house/shop tank. I have a small Onan 2cyl. that came out of a motorhome that I mounted on a trailer with tank off of motorhome for fuel supply. Portable power. No fancy diffuser or regulator, just ran a small 1/4" copper tubing to top of carb. Push button to start, then open valve on tank, works ok.
I have a govnerner on the engine.It only runs 1800 rpm,just a good fast idle.Right now it runs on a 20# bottle but don't know for how long.
Mike
   / Stand-by generator #9
Great project. That's a lot of motor for a 6.5KW gen. Does your 1800 RPM give you a steady voltage and 60 cycle frequency? At that RPM fuel usage should be minimum. Good standby power supply. If the rating is 6.5KW continuous you can probably run a small house with minimal load. I ran a 5KW as my house backup power for a couple years before getting a larger 10KW gen.
Thanks,George. The generator is rated at 1800 rpm.It pulls down A little at the first hard load but recovers quickly.I'm gonna hook it to the house soon & see what it does.I post it here after I try it.
20ft Bi-Parting Gate (A51573)
20ft Bi-Parting...
NEW  Ripper Shank (A53002)
NEW Ripper Shank...
2018 FORD F-550XL SERVICE TRUCK (A51406)
2018 FORD F-550XL...
Guard Rail Joints (A51692)
Guard Rail Joints...
Echo SRM2620 Gas Trimmer (A52377)
Echo SRM2620 Gas...
2020 UNVERFERTH 332 LOT NUMBER 199 (A53084)
2020 UNVERFERTH...
