stalling
/ stalling #1
PEU
Pine Bush,NY
sub compact cub sc2400 3cyl yanmar
I have a cub sc2400 3cyl diesel with 50hrs.after warm up (10 mins)it shakes,stalls with blue white smoke,only after it sits will it start with blue white smoke.Can some help.:confused2:
/ stalling #2
Check for water in your filter unit on the left side of engine. Follow manual for dumping if water is seen in bottom. How new is your fuel? Do you use an additive? How full is your tank and could you have condensation in there? Most important, call the dealer first thing Monday. Good luck.
/ stalling #3
Check your fuel filter. It could be pluuged up with water, dirt or even waxed off. I had mine acting this way and it looked fine but when I pulled it out I could see a coating of wax like substance, Installed new filter bled out the air and all was good.
/ stalling #5
A wax like substance are you burning straight #2 what temp is it there could you be gelling your fuel?
2018 Ford F250 4x4 Ext. Cab Pickup Truck (A64194)
2018 Ford F250 4x4...
Ford 3910 Tractor w/ Great Bend Loader (A64047)
Ford 3910 Tractor...
John Deere XUV825E (A61307)
John Deere XUV825E...
Frontier Quick Attach Pallet Forks (A64126)
Frontier Quick...
2019 CATERPILLAR CP54B PADFOOT ROLLER (A62129)
2019 CATERPILLAR...
New/Unused AGROTK Wheel Balancer (A65583)
New/Unused AGROTK...
