stalling
   / stalling #1
PEU
Pine Bush,NY
sub compact cub sc2400 3cyl yanmar
I have a cub sc2400 3cyl diesel with 50hrs.after warm up (10 mins)it shakes,stalls with blue white smoke,only after it sits will it start with blue white smoke.Can some help.:confused2:
   / stalling #2
Check for water in your filter unit on the left side of engine. Follow manual for dumping if water is seen in bottom. How new is your fuel? Do you use an additive? How full is your tank and could you have condensation in there? Most important, call the dealer first thing Monday. Good luck.
   / stalling #3
Check your fuel filter. It could be pluuged up with water, dirt or even waxed off. I had mine acting this way and it looked fine but when I pulled it out I could see a coating of wax like substance, Installed new filter bled out the air and all was good.
   / stalling #5
A wax like substance are you burning straight #2 what temp is it there could you be gelling your fuel?
2011 Ford Explorer Limited AWD SUV (A50324)
2011 Ford Explorer...
2012 MACK GU713 DUMP TRUCK (A51406)
2012 MACK GU713...
2018 CATERPILLAR 326FL EXCAVATOR (A51242)
2018 CATERPILLAR...
2016 J&M 1122-20T X-Tended Grain Cart (A50657)
2016 J&M 1122-20T...
UNUSED FUTURE FORKLIFT TELESCOPIC BOOM (A51244)
UNUSED FUTURE...
2007 Case IH 2588 4WD Combine (A50657)
2007 Case IH 2588...
