STALLED 2000 Ford.3 cyl gas.no start ,gearbox switch?
   / STALLED 2000 Ford.3 cyl gas.no start ,gearbox switch? #1
CHEEKS
FORD
stalled tractor in gear,wont turnover now,,power to solenoid,,i think its gearbox switch,can i jump it etc?..thankyou
   / STALLED 2000 Ford.3 cyl gas.no start ,gearbox switch? #2
I do not own that model but lets work through the optoins.
Assume 12 V negative ground chassic
12V positive to solenoid
possible clutch pedal safety interlock
possible neutral gear box interlock
on the solenoid there could be a small jumper that connects to the large positive,
that would be the pull in coil
the pull in coil pulls a plunger forward moving the bendix and at the last moment the
main contact makes providing the heavy current 12V to turn over the engine.
This is off the top of my head, a jumper wire will complete the circuit to the pull in coil.
I would make sure the clutch is down , the key is in the run position and do the jump connections with a helper in the driver seat.
Work carefully
Craig Clayton
THANKS CRAIG,,I JUMPED SOLENOID FOR A SEC,,THEN IT WORKED,I THINK SOMETHING WAS STUCK WHEN COLD,,JIM Assume 12 V negative ground chassic
Work carefully
Craig Clayton[/QUOTE]
   / STALLED 2000 Ford.3 cyl gas.no start ,gearbox switch? #4
Neutral safety switch goes into transmission top caver left center, this has a two wire plug that you can bypass the safety switch and prove if that is the problem. If no change, small wire to starter solenoid on right side just a short distance from starter can be jumped to battery side of solenoid and starter should crank, Be safe, check for neutral both shift levers and brake on.
2012 UNVERFERTH 6-INCH FRONT WHEEL SPACER KIT FOR 10 BOLT HUB (A52748)
2012 UNVERFERTH...
(30) 24-A Macro Bins (A50121)
(30) 24-A Macro...
2011 Ford F-150 4x4 Crew Cab Pickup Truck (A50323)
2011 Ford F-150...
2006 IC PB30500 School Bus (A50323)
2006 IC PB30500...
2016 JLG 3248RS 32ft Electric Scissor Lift (A50322)
2016 JLG 3248RS...
2016 Toro Groundsmaster 3505D 72in Rotary Mower (A51691)
2016 Toro...
