Stake rack
/ Stake rack #1
Deerlope
Northern, New York
Kubota L3830 03: RTV 900
I would like to post the pic's of the rack I built for my RTV but I am have a heck of a time trying to resize them. Moderater's could we please have an auto sizer installed.
/ Stake rack
Pic #2
/ Stake rack
pic #3
/ Stake rack #4
Fred,
We need some "close-ups"!!!
Nice setup but how do we copy it if we can't see the details? /forums/images/graemlins/shocked.gif /forums/images/graemlins/grin.gif /forums/images/graemlins/wink.gif
Looks like you got a good amount of wood on there... I made my own box and leave the tailgate open so I can get a 3rd rank on. Probably not as much as you're carrying but it's working for me so far. /forums/images/graemlins/wink.gif
Brian
/ Stake rack
No close up needed. All you have to do is take 1'x1'X1/8" hollow square tube the height that you want the rack and weld a piece a of 2 1/2"x 1/8" flat bar to that , on the front corners weld two pieces on to make the corners. Put the weld on the inside so it looks good & smooth on the outside. I used white ash lumber, 1/4" carriage bolts and self locking nuts. Keep the bolts about 1" from the end of your wood slates. I use a mixture of 50/50 % turpintine& linseed oil on the wood and be sure to paint the metal.
/ Stake rack
I will never over load it. That is dry wood might have 6-8 hundred pounds on in that pic. I made them that high so I could haul lighter, bulkyer material like leaves or wood chips. baled hay etc. My dealer told me that he had one guy that was bring out a cord to the load, probably about a ton. Payload is 1600 lbs.
/ Stake rack
Close-ups
/ Stake rack #10
</font><font color="blue" class="small">( My dealer told me that he had one guy that was bring out a cord to the load, probably about a ton. Payload is 1600 lbs. )</font>
I'm assuming that's a "face cord" (1 rank, 4x8'). No way to fit a full cord (128 cu/ft) in the box as you would need to stack it over 8' high. /forums/images/graemlins/shocked.gif
The wood I've been hauling is nice wet oak or maple. I think I'd probably either tip over of flip over backwards if I filled it up using your racks. I put about 1200# in mine with no racks which is a full enough load for me. /forums/images/graemlins/wink.gif
/ Stake rack
I am sure he was referring to a face cord, but that is still a lot of weight. We all got common sense and I sure am gonna keep using mine.
/ Stake rack #13
Last year I bought a full cord of wood with a friend of mine. We brought up to deer camp and hauled it in with my RTV, a bunch of straps and a small trailer that I pulled behind my RTV. We made three trips to get it all in. That was the most weight I ever carried and pulled with my RTV. Everyones jaw just dropped when they saw that. I could not believe it myself. I was on mainly level ground so that helped. If I had stake sides I would have hauled even more. The RTV's are an amazing machine.
Giyi Mini Excavator Attachment Set (A64912)
Giyi Mini...
2025 JMR 8ftx4ft Safety Basket Skid Steer Attachment (A66734)
2025 JMR 8ftx4ft...
Mack T/A Day Cab Truck Tractor (A64556)
Mack T/A Day Cab...
2018 GENERAC MOBILE PRODUCTS  MTL6S (INOPERABLE) (A67714)
2018 GENERAC...
CAT 330BL Swing Drive (A68134)
CAT 330BL Swing...
CAT 953C Cab (A68134)
