stabilizers
   / stabilizers #11
</font><font color="blueclass=small">( My woods RFM is a bear to get on. Maybe it will get easier after a little wear?. )</font>
Try greasing the shaft and inside the PTO coupler.
Make sure you have cleaned off any grit on each or it can wear your shaft pretty quickly.
I keep a can of lithium delayed viscosity spray grease handy for just such purposes.
John
   / stabilizers #12
Thanks KJ.
I'll try the Lithium grease. If I put any more of that red General purpose grease on it, I won't be able to see the splines.
I've yet to master pulling the snap collar back while pushing the coupler on.
Tom
   / stabilizers #13
According to the owner's manual:
Tight sway/check chains for brush hog, mowers, hay rake, tedder & ridger
Loose (2 - 2.5" sway) for plows, furrower, sub-soiler, cultivator & ditcher
Better to follow recommended procedures
   / stabilizers #14
</font><font color="blue" class="small">( I've yet to master pulling the snap collar back while pushing the coupler on.
)</font>
I have the Woods finish mower also and the pull / push design seems sort of counter-productive and a pain in the butt.
My King Kutter rotory mower has a verticle pin you push down then slide the coupler on, much easier.
I would have thought the easier design would be on the higher priced Woods unit.
Larry
   / stabilizers #15
</font><font color="blue" class="small">( Better to follow recommended procedures)</font>
That's what I said!! /forums/images/graemlins/grin.gif
John
   / stabilizers #16
<font color="blue"> </font> (That's what I said)
<font color="black"> </font> You are absolutely correct. As the kids say "My bad".
Gotta pay closer attention to the text in the thread. /forums/images/graemlins/blush.gif
2017 Ford Fusion Hybrid Sedan (A56859)
2017 Ford Fusion...
CATERPILLAR 627K SCRAPER (A52707)
CATERPILLAR 627K...
HYDRAULIC TILTING BUCKET FOR MINI EXCAVATOR (A58214)
HYDRAULIC TILTING...
2000 Kenworth W900 - 3406E CAT Engine - 78,980 Miles (A55302)
2000 Kenworth W900...
2006 CEI  DRY BULK TRAILER (A58214)
2006 CEI DRY BULK...
2020 PETERBILT 567 (A58214)
2020 PETERBILT 567...
