Soundguy
Old Timer
- Joined
- Mar 11, 2002
- Messages
- 52,238
- Location
- Central florida
- Tractor
- RK 55HC,ym1700, NH7610S, Ford 8N, 2N, NAA, 660, 850 x2, 541, 950, 941D, 951, 2000, 3000, 4000, 4600, 5000, 740, IH 'C' 'H', CUB, John Deere 'B', allis 'G', case VAC
Silver solder will require lower heat than brass.. but more heat than regular solder.. however silver solder will withstand more abuse than regular solder.
Lots of dbl barrel shotguns have silver solvered center ribs.. also.. I know the oil pump pickup tube in my ford tractos are silver soldered to the oil pump... sticks to steel/iron VERY good.
I'd run the damaged section well away from the wiper and seal.. and if I couldn't get more than 4" away.. I'd lay a wet rag over the metal right next to the seal.
For the real electronic buffs.. you can get a solder het protector gell and can lay abead on the seal.. it was made to 'pot' / heatsink components and wick heat away to prevent them from cooking while soldering.. etc.
soundguy
soundguy
