Stabilizer links on BX2200
   / Stabilizer links on BX2200 #11
Milkman,
I missed this one when it was posted, great job!!
The turnbuckles on the BX were getting on my nerves too.
After getting the Quick Hitch, I made my last adjustment, and haven't had to futz with them since.
If i ever go back to standard set-up, I'll consider this modification, looks like a winner!
:D
   / Stabilizer links on BX2200 #12
Very nice job. I've got the same tractor and would like to do this to it too. Did you make the all the parts or order some of them? If you ordered them, where did you get them?
Another hitch mod that worked for me and would recommend:
At the end of the summer I bent one of my lift arms and some of the linkage because I didn't have the turnbuckles tight and I was trying to pry out a small dead stump with the back blade (real cause). Anyway when I removed the hitch I cut 2.25" out of the solid lift link (the one the lifts the left arm), machined a sleeve to fit over the lift link rod, slid it on one end of the rod, welded the two halves back together, slid the sleeve over the weld and then welded the ends of the sleeve in place to further reinforce the rod. Now I can pick the back blade up two feet in the air, before it would drag or catch if went up a hill. I'm also not dragging my yanmar tiller here and there across the yard. It's much nicer for plowing snow since you can lift it up fairly high.
JOHN DEERE 560M LOT NUMBER 15 (A53084)
JOHN DEERE 560M...
2018 John Deere TX (A53317)
2018 John Deere TX...
2017 Ford F-250 Enclosed Service Truck (A53422)
2017 Ford F-250...
Kubota B2301 (A53317)
2014 Ford F-550 4x4 Altec AT37G 37ft. Bucket Truck (A55852)
2014 Ford F-550...
2018 Ford F-250 4x4 Crew Cab Gooseneck Service Truck (A51692)
2018 Ford F-250...
