Rotary Cutter Stabilizer Brace for Brush Cutter?
/ Stabilizer Brace for Brush Cutter? #1
To20Chris
Platinum Member
Hereford, PA
LK3054
This is related to my other post about limiter chains, but a bit different question. In changing my Dixie Cutter over from my TO20 to my LK3054, I'm taking a look at how I have it set up. I've always run it with a stabilizer brace - don't know why, it was set up like that when my dad got it when I was a kid. Now I'm wondering, how do most people set up a brush cutter? Would it be better to let it swing free with limit chains? It's a Woods Dixie Cutter M5 with a single rear wheel.
Hmm - looks like that is designed to control heigth. Come to think of it, since the Ferguson does not have position control, I use vertical limit chains too, but it also has a rigid horizontal brace to the diff case out by the wheels. If the lift limit chains are tight they will limit the side-to-side sway too, but I don't need them on the Kioti. So I guess the question is, on the Kioti should I control the side to side sway tightly, or let it move until it hits the limiter chains?
/ Stabilizer Brace for Brush Cutter? #4
I use both, to hold the cutter deck in a rigid straight line behind the tractor. Saves a whole lot of wear and tear on fence posts when mowing up close.
//greg//
I think you are right - I've always liked the way it tracked behind the tractor. If it was free to move laterally, I would have a lot less confidence about where it was relative to the tractor wheels. Reverse could get quite interesting too! I think I will set it up on the LK3054 the same way. In reality, with the narrower track on the new tractor, I would not have much room to let it move anyway.
Thanks!
/ Stabilizer Brace for Brush Cutter? #6
</font><font color="blue" class="small">( So I guess the question is, on the Kioti should I control the side to side sway tightly, or let it move until it hits the limiter chains? )</font>
Owner's manuals usually recommend no sway. My brother says leave a little sway so that if you come up against the side of a tree, trying maneuver around, the little bit of sway will help. I keep mine pretty tight. It does make for more accurate backing. If you leave any sway, don't let it be very much. John
/ Stabilizer Brace for Brush Cutter? #7
I have no sway but I mow alot of hillsides.
/ Stabilizer Brace for Brush Cutter? #8
</font><font color="blue" class="small">( I have no sway but I mow alot of hillsides. )</font>
tough451, I'm glad you brought that up as it could be an important safety issue I would imagine. I would think that with sway, the momentum as the mower pulls to the downside might cause the tractor to start slipping down a little, maybe a lot. I hadn't thought of that one. Thanks, John
/ Stabilizer Brace for Brush Cutter? #9
</font><font color="blue" class="small">( </font><font color="blueclass=small">( I have no sway but I mow alot of hillsides. )</font>
tough451, I'm glad you brought that up as it could be an important safety issue I would imagine. I would think that with sway, the momentum as the mower pulls to the downside might cause the tractor to start slipping down a little, maybe a lot. I hadn't thought of that one. Thanks, John )</font>
Yes it will pull to the downside and if conditions are right bad things can happen.
/ Stabilizer Brace for Brush Cutter? #10
On my NH 1920.. there are chains from the axle mounts to the 3pt arms to limit sway.. much in the same way your solid brace on your to-20 ( and ford N-series ) used a under the fender bracket for the brace.. etc.
Yes.. I would rig up a chain brace.. etc... you don't want eny implement hitting a tire..
Soundguy
2018 Regal 29OBX 29ft Boat with 34ft T/A Boat Trailer (A61569)
2018 Regal 29OBX...
2017 Chevrolet Tahoe SUV (A64194)
2017 Chevrolet...
6x12 Leonard Utility Trailer (A65579)
6x12 Leonard...
John Deere AH202558 25ft Full Finger Auger (A65640)
John Deere...
2020 ISUZU NPR 16FT BOX TRUCK (A59914)
2020 ISUZU NPR...
2021 CAT 299D3xe Skid Steer w/ 2021 CAT HN415c Mulching Head (A62613)
2021 CAT 299D3xe...
